Tesla Inventory
Startet av Nasatech, tirsdag 29. august 2017, klokken 15:01
Jeronan
Sitat fra: Amoss på mandag 09. oktober 2017, klokken 15:46
Sitat fra: Jeronan på mandag 09. oktober 2017, klokken 11:05
I heard that these inventory cars are non-sold leftovers from US market.
So not very likely. They should be produced for the EU/ESA marked and therefor is somewhat different then the cars sold in the US.
Yes I got that as answer. Made for Norwegian market. The tires are also changed to proper summer tires and not those horrible Goodyear All-season crap tires that are outright dangerous in Norwegian climate.
So I canceled my current order and switched to one of the new incoming Inventory. :) At least I have now a guaranteed delivery before beginning December.
Model Y - Sept 2021
Model S 75D - Sold
BMW i3 2017 - Feb 2017
elfosilen
Er det noen måte å finne ut når disse inventory-bilene ble produsert?
Jeronan
Sitat fra: elfosilen på mandag 09. oktober 2017, klokken 20:23
You can check the page of the car you interested in, right click on the main picture, copy and then paste the link in here:
http://options.teslastuff.net/
If it has APH3 code, then it's produced in August and if it still has the APH2 code then it's a July produced car. More or less.
Most of the cars in that list have the APH3 code, but a few still have the APH2 code (most of these are the non-leather interior and non-premium ones).
The one I now changed the order to has the APH3, DU00 and SR07 code. So all the new stuff (hopefully :P).
Model Y - Sept 2021
Model S 75D - Sold
Jeronan
Model Y - Sept 2021
Model S 75D - Sold
Daniel80
Spørsmål: Har funnet ut at Model S biler med VIN som starter på 213xxx har de nye baksetene, mens VIN til og med 212xxx har de gamle.  Vil dette stemme for inventory biler også?
Min bil er så forsinket, så har fått tilbud om å bytte til en inventory. Fikk først tilbud om en med VIN 208xxx, men takket nei pga gamle bakseter. Har nå funnet noen inventory med 214xxx og 215xxx, og lurer på om jeg kan gå utifra at de har alt det nyeste utstyret med tanke på både effektøkning, oppgradert lader, nye bakseter +++ ?
Model 3 LR AWD Boost, H&R senk, 9,5x20 ET30 245/35-20 square,
Jeronan
Sitat fra: Daniel80 på tirsdag 10. oktober 2017, klokken 10:11
It seems it has to be do with the chosen options as well. I have seen a Model S with VIN 218xxx, with standard textile seats and no Premium package still having the APH2 hardware, while the Model S I have chosen now has VIN 213xxx, with leather seats and Premium package has all the latest hardware, including SR07 rear seats.
So a higher VIN number doesn't give immediate guarantees, as the cars don't get produced based on order of VIN number.
So you can have some variation there, where some cars with lower VIN number where actually produced at a later date.
If you want to be sure, you can either call a Tesla sales person and give him the VIN number to check, or click on the car you want in the Inventory site that leads you to the Tesla inventory page of this car, right click the main picture and paste the result here:
If it has APH3, then it will almost certainly also have the DU00 drive unit and SR07 back seats.
Model Y - Sept 2021
Model S 75D - Sold
El Pastor
Noen som vet om det nye bakseter på model x også? Har både aph3 og du00, men sr05.
Jeronan
Sitat fra: El Pastor på tirsdag 10. oktober 2017, klokken 12:28
The Model X has completely different type of back seats. Like the new ones for example can recline backwards. Something that is of course not possible on the Model S.
So SR05 could be right for the Model X, but if you want to be sure, call your local sales person and he can verify in the system what seats you will get on this car.
Model Y - Sept 2021
Model S 75D - Sold
El Pastor
TeslaModelX
⇳ = Luft
℗ = Premium
➋ = Soltak
❄ = Vinterpakken
♫ = Lydpakken
➁ = Oppgradert autopilot (AP2)
➋ = Oppgradert Autopilot og evnen til å kjøre helt på egen hånd (AP2)
Soltak har vel feil ikon i forklaringen? ;)
Nasatech
Sitat fra: ModelS på torsdag 12. oktober 2017, klokken 18:09
⇳ = Luft
℗ = Premium
➋ = Soltak
= Vinterpakken
♫ = Lydpakken
Ja. Dæven. Det må fikses :)
tibber73
Sitat fra: Nasatech på torsdag 12. oktober 2017, klokken 18:23
⇳ = Luft
℗ = Premium
➋ = Soltak
= Vinterpakken
♫ = Lydpakken
Sortering på VIN er litt merkelig.
Ellers er denne siden meget bra  :+1:
Tesla Model S 75D, VIN 226XXX, 14.12.2017
Tesla Model 3, reservert 01.04.2016 07:00, kansellert 03.2019
Nissan Leaf Tekna, VIN 6011XXX, 26.03.2014, solgt 01.2020
Nasatech
Sitat fra: terje73 på torsdag 12. oktober 2017, klokken 18:47
⇳ = Luft
℗ = Premium
➋ = Soltak
= Vinterpakken
♫ = Lydpakken
Fikset soltak :)
VIN blir litt merkelig sortert fordi man ikke ser helen VIN. Tenkte kanskje å se litt på det, men ikke så veldig viktig å sortere på VIN, så vet ikke hvor mye jeg skal legge i det.
tibber73
Sitat fra: Nasatech på torsdag 12. oktober 2017, klokken 20:22
⇳ = Luft
℗ = Premium
➋ = Soltak
= Vinterpakken
♫ = Lydpakken
Fikset soltak :)
Jeg regna med at det var årsaken, ja.
Bruker VIN for å sortere på produksjonstidspunkt (ikke helt riktig da VIN tildeles i batcher).
