Speedometer problem
Startet av rzepon, tor 28. okt 2021, kl. 01:29
rzepon
Hello
In my old 2000 Think speedometer didn't work since few days :-(
It has 98900km stand
Any sugestions whats wrong with it
Rzepon
Best to simply swap it with a working unit. If that does not help the next step is to look at the source of the signal
I have a several instrumenter, and you can have one for 100 NOK pluss freight
rzepon
It's possible to drive without dashboard instruments?
Georgie
Hi, I had the same problem on my Think at around 60 000 km. Just unplugged and plugged the connector on the back of the speedometer (blue) and it has worked like treat since then (only a few km away from 90 000 km now).
George
2000 Think City
rzepon
Thank You Robort :-)
Your speedometer is working good.
I'm looking for what is braking in my item now.
Good to hear. You got a Miles instrument for free, but I have in Km also. I would need to charge the labour to remove it though.
rzepon
My original speedometer is working again. My friend check all and didn't find any damaged electronic elements.
