2026 Koenigsegg Gemera 850 V 14 kWt PHEV LadeHybrid
Startet av elekTrond, søn 04. okt 2026, kl. 18:15
elekTrond
Lite liv her på PHEW-forumet, så jeg hiver ut dette agnet. Endelig kom Ge-Mera ut. Har sett eller fått foreslått raxial/radial-flux motoren dems på youtube i ørten år. =]
BTW: Er det igjen noen E85 pumper i Norge? Jeg fylte E85 fram til 2013. En gang rundt de tider fjernet Norol Statoil(?) CircleK pumpene, både fra kartet og fysisk ;'(
SitatThe HV8 powertrain has a combined power output of 1,715 kW (2,300 hp; 2,332 PS) and 2,750 N⋅m (2,028 lb⋅ft) of torque[12] when the engine runs on E85 fuel.
Koenigsegg Gemera
The name is a combination of the Swedish words ge and mera, which translate to "give more".[11]
Production 2026[1]–present
Electric motor
1x Dark Matter 600 kW 1250 Nm
2x 373 kW 1000 Nm
Hybrid drivetrain PHEV
Battery 850V 14 kWh[6]
Electric range 50 km (31 mi)[3]
Kerb weight 2,042 kg (2023 production)[5]
146 kg bil per kWt
Leselyst:
Sitat[...] Combined with the three electric motors, this powertrain produced a combined 1,400 hp (1,044 kW; 1,419 PS).
Electric motors
Three electric motors are included, one for each rear wheel with 373 kW (507 PS; 500 hp) and 1000 Nm each and the Dark Matter motor on the front axle with 600 kW (800 hp) and 1250 Nm.[14]
The Dark Matter motor is 380 mm (15.1 in) in diameter and 390 mm (15.3 in) thick, for a total weight of 39 kilograms (86 lb). It uses a "raxial flux" design; an axial flux design complemented by a smaller radial flux component to flatten the torque response curve and reduce torque ripple. It uses carbon fiber to minimize weight for the rotor, stator, and housing. It is a six-phase motor instead of the conventional three-phase design.[14]
It comes with an 850V 14 kWh battery pack.[14]
c",)
'13 Mjau
