Charging blocked by erroneous High Temp reading of 120degC
Startet av Myles Twete, tor 18. jun 2026, kl. 20:26
Myles Twete
One of my THINKs has stopped charging.
From CAN traffic during attempted charging, we see:
    Findings/Sequence:
        0 secs: CAN trace started
        13 or 14 seconds: Charge plug inserted
        14.4266secs: Charger announces itself on CAN (0x350)
        14.4730secs: Charger Status 1 (0x353) Msg indicates charger ready
        14.5266secs Charger Status 2 (0x354) Msg reports 120C Input Temp right from the start
        14.5791secs Charger Error (0x355) Msg reports no charger errors
        23.2777secs Charger Error Msg issues HighTemperatureShutdown Error
        23.3837secs Charger Status 1 indicates Recoverable Error
        23.6142secs PCU disables charger (0x352)
The car runs fine and I thought that if I drive it around a bit, maybe I'd find this to be a temporary issue.
We see that the charger immediately reports input temperature of 120degC immediately after announcing itself.
And so I think this is erroneous data.
Unfortunately, the Charger itself responds to the high temperature by setting a High Temp Shutdown and notes it as a Recoverable Error.  PCU takes this information and either tells the charger to shutdown or recognizes it...
It seems then that there is no choice but to replace the charger.
Has anyone else seen this?  It seems to me that the temperature measurement is an error.
Anyway, I thought I would share.
Warlock
It might be the temperature sensor (thermistor) in the charger (or a resistor in series with it to create a voltage divider for the sensing) is damaged/worn out/shorted... If i remember correctly, the usual upper limit for a 10k NTC thermistor is about 120degrees Celsius...
If you have to take out and open the PCU, I guess there is no big job to measure it at least, and maybe even change it (they are easily available)....
Warlock
Had a look at your attached file, might it be a wrong one? Found no 0x350 - 0x355 CAN messages....
Myles Twete
#3
Sitat fra: Warlock på tor 18. jun 2026, kl. 21:26Had a look at your attached file, might it be a wrong one? Found no 0x350 - 0x355 CAN messages....
Good catch --- tusen takk!
I just replaced the trace with the correct one.
I also just checked the Eltek spec and see that indeed the charger will shut down if if the temperature on the Input is above 110degC, Output is above 100degC or Transformer is above 107degC.  Sure would be nice if there were a way to override the error...
-Myles
Warlock
Unfortunately, I don't think it is possible to override the sensor/software through CAN messages. At least not with any of the ones which is documented in the manuals...
Myles Twete
Sitat fra: Warlock på fre 19. jun 2026, kl. 11:29Unfortunately, I don't think it is possible to override the sensor/software through CAN messages. At least not with any of the ones which is documented in the manuals...
Yep.  Also, it's clear that the charger itself is shutting down based on its own criteria for temperature limits.  And so, I have little choice but to replace the charger.  Fortunately, I have several ~new Eltek-Valere chargers, so it's just a matter of spending 14 hours of quality time bending over the front of another THINK. :-)
-Myles
Warlock
Yes, you will by all means have to take out and open the PCU.
Are you willing to part with/sell the dysfunctional charger? It would be fun to have a look at it at one point...
Maybe Marsto has room for it in his luggage this late summer/autumn?
Marsto
Sitat fra: Warlock på tir 23. jun 2026, kl. 17:48Yes, you will by all means have to take out and open the PCU.
I got room...even for a few ptc elements to use for our upcoming long and dark winter here in the arctic....maybe Santa Claus would be able to find room in the sled for an early trip to Arizona in october or early november?....I would pay extra for that trip, for sure...... ;)  ;)  :D  :+1:
Myles Twete
I have 6 or 7 chargers---all of them with THINK programming.  Four of them are essentially unused.  One of these will replace the one in the red car when I get it removed.  I would like to later take that charger apart to see what it is like inside---it could be that things were indeed getting too warm over time and something oozed onto the Primary thermistor, reducing the resistance read over time.  The charger has for over a year now reported high Primary temperatures while charging and the fan would turn on and run for much of the charging time.  Temperatures would often read around 200degF---which is 50 to 90degF higher than the charger in my other THINK.  I think I have 2 chargers that failed back in the 2014 timeframe---John Mayer handed me those to see if I could figure out what all was damaged and whether I could fix them or not...I did attempt to get them running a couple of years ago now (replaced power devices and HV capacitors) but chargers still didn't work.  When these fail, there usually are melted capacitors and/or precharge resistor(s).
