Skrevet av Emne: OVMS for Think  (Lest 44859 ganger)
BauDemo
    • www.uppladdning.nu
OVMS for Think
« på: Onsdag 19. Desember 2012, klokken 16:09 »
I just ordered an OVMS unit and plan to make it compatible with the Think.
More info on OVMS: http://www.openvehicles.com/node/32
It is currently used on Tesla Roadster, but the software is open source and should be possible to adapt to work with the Think.
I purchased it from here:
http://www.fasttech.com/products/0/10000001/1000300-ovms-car-module-v2
For those of you that have RAC module in the car that does not work, you can replace it with this and use the existing antennas (GPS and GPRS)...
Anyone up for this project?
Edit:
Link to video of the iphone app:
http://www.youtube.com/watch?v=CSh-Mdf-QKo
http://www.youtube.com/watch?v=v1oGXYngI3c
« Siste redigering: Onsdag 19. Desember 2012, klokken 16:11 av BauDemo »
Lynet
Sv: OVMS for Think
« Svar #1 på: Onsdag 19. Desember 2012, klokken 18:42 »
Jeg er med :D
« Siste redigering: Onsdag 19. Desember 2012, klokken 18:44 av Lynet »
Trondheim:
Tesla X100D 2019 modell.
Sv: OVMS for Think
« Svar #2 på: Onsdag 19. Desember 2012, klokken 19:01 »
I don't quite see what this can do, but anything that gives more driver info interests me.
I'm in.
Selger utstyr for EV lading og energieffektivisering via http://Elbilhjelpen.no AS
Lynet
Sv: OVMS for Think
« Svar #3 på: Onsdag 02. Januar 2013, klokken 16:16 »
Har du fått OVMS i løpet av jula BauDemo? Må si at jeg er skikkelig spent på dette  :D
Trondheim:
BauDemo
Sv: OVMS for Think
« Svar #4 på: Onsdag 02. Januar 2013, klokken 20:05 »
Yes, I got it and I have started coding. I had some problems, but I am up and running now. Today I got my first response from the car - and it was only SOC, and then it turn out I had the wrong bytes... so there is still some work to be done.
It is very cool!!
BauDemo
Sv: OVMS for Think
« Svar #5 på: Søndag 06. Januar 2013, klokken 09:37 »
Screenshot of sms communication.
Lynet
Sv: OVMS for Think
« Svar #6 på: Søndag 06. Januar 2013, klokken 11:54 »
Kjempebra  :D
Dette blir spennende.
Trondheim:
jahnarne
Sv: OVMS for Think
« Svar #7 på: Tirsdag 08. Januar 2013, klokken 21:27 »
Superspennende. Jeg har bestilt og venter på OVMSen. Har fått Pictprogrammerer.
BauDemo
Sv: OVMS for Think
« Svar #8 på: Tirsdag 08. Januar 2013, klokken 23:03 »
Great! I could really use some testing help, and feedback.
Did you order the antennas?
If not you may want to try the built-in antennas that are (or should be) there for the RAC unit. I found a supplier for an adapter from the plugs for the RAC to the plugs on the OVMS.
jahnarne
Sv: OVMS for Think
« Svar #9 på: Onsdag 09. Januar 2013, klokken 08:44 »
Bestilte med antenner ja. Har en 2011-modell, så ingen RAC. :)
BauDemo
Sv: OVMS for Think
« Svar #10 på: Onsdag 09. Januar 2013, klokken 11:14 »
Are you sure that the wiring harness and the gprs/gsm antennas are not installed anyhow?
Go-carter
  • Racing is life.
Sv: OVMS for Think
« Svar #11 på: Onsdag 09. Januar 2013, klokken 20:08 »
Mostly only the 2008 models, and the pre-production ones that got this. I have a complete cable loom with the RAC-wires, and antenna from my racing-think.
TMX60D
Leaf S 2015
BauDemo
Sv: OVMS for Think
« Svar #12 på: Onsdag 09. Januar 2013, klokken 23:05 »
Interesting... have you worked for Think, and seen this or other source? I am asking because I am looking at 3 Thinks from 2009, Norway VIN up to 153, that have the antennas, wiring and RAC... But maybe these are special?
Lynet
Sv: OVMS for Think
« Svar #13 på: Torsdag 10. Januar 2013, klokken 11:52 »
Jeg har 2009 modell 5017, den har RAC og GPS-antenne.
Airbaglampe lyser så jeg ser frem til å få ut RAC og inn med OVMS.
Trondheim:
Go-carter
  • Racing is life.
Sv: OVMS for Think
« Svar #14 på: Torsdag 10. Januar 2013, klokken 12:17 »
Naaah, I was just guessing. But seems as I guessed wrong :) My racing-think has a 5xxx VIN-number as well, so it isnt a pre-production model.
TMX60D
Leaf S 2015
