Zebra BMI charger type
Startet av svilen, tir 24. aug 2021, kl. 05:55
svilen
Hello,
I bought a car with a zebra battery,
who had a problem with the charger in the PCU, I fixed the hardware problem. Now the PCU is working. :)
However, the Zebra's BMI is set to charge from another charger (round connector on zebra BMI unit) . I need to set it to the standard charging method (from PCU)
Does anyone have any information for can messages between Zebra BMI & Zebra monitor (ID: 500h,520h,530h).
I don't have zebra software & Peak can adapter
I need a way to change only this parameter: charger type
May be some direct CAN message to Zebra BMI will do the Job.
Thanks!!!
pexic
Where are you located ? maybe there is someone here close to you and help you with the Peak adapter.
svilen
Sitat fra: pexic på tir 24. aug 2021, kl. 09:59
Hi, I'm in Sofia, Bulgaria.
Thanks
pexic
#3
Hi Svilen.
I can send you the zebra software -please send me a private message with your email.
Regarding PEAK adapter you have two choices:
1- buy one (new is about 200 eur as far I remenber, from Germany) - https://www.peak-system.com/PCAN-USB.199.0.html?&L=1&gclid=CjwKCAjw95yJBhAgEiwAmRrutHcgqmf9T5ZkfG3Ef955GHJghFZuPa92hID7kXOD6IYxFil5JgEEXxoC9rUQAvD_BwE
2-two trips to Bucharest and I can borrow you the adapter.
good luck !
