Oppdatering av Elbilforum
Startet av phaugneland, tor 12. mar 2020, kl. 15:05
Elbilforum admin
The following significant events have been noted:
2022-05-03 - 01:00 - Maintenance begins
2022-05-03 - 06:00 - Maintenance ends
Total Service window time: About 5 hours.
Elbilforum admin
2022-05-24 - 01:00 - Maintenance begins
2022-05-24 - 06:00 - Maintenance ends
Elbilforum admin
2023-03-07 - 01:00 - Maintenance begins
2023-03-07 - 06:00 - Maintenance ends
Elbilforum admin
#93
2023-03-22 - 07:30 - Maintenance begins
2023-03-22 - 14:00 - Maintenance ends
Total Service window time: About 6 hours
Elbilforum admin
2023-05-02 - 01:00 - maintenance begins
2023-05-02 - 06:00 - maintenance ends
In this maintenance window, we will perform a necessary reboot a central server. This may cause some routers to perform a failover.
 This is usually very minor, and not noticeable for most. In some rare cases, it can cause disturbances that exceed this, and is the reason we choose to give you a heads up.
No configuration changes or software changes are performed as a result of this maintenance.
Elbilforum admin
2023-05-16 - 01:00 - Start of maintenance
2023-05-16 - 06:00 - Maintenance finished
Elbilforum admin
2024-04-09 - 01:00 - Maintenance begins
2024-04-09 - 06:00 - Maintenance ends
Elbilforum admin
2024-04-30 - 01:00 (Service window begins)
2024-04-30 - 06:00 (Service window ends)
Elbilforum admin
2024-05-07 - 01:00 (Service window begins)
2024-05-07 - 06:00 (Service window ends)
Elbilforum admin
2024-08-20 - 01:00 (Service window begins)
2024-08-20 - 06:00 (Service window ends)
Elbilforum admin
Maintenance on Nordic Cloud (v1) networking API
This message is sent to you in order to inform about an event that affects the
operation of one or more of your systems managed by Redpill Linpro.
2025-05-20 - 01:00 (Service window begins) - Maintenance begins
2025-05-20 - 06:00 - Maintenance over
In this maintenance window, the servers that host the old OpenStack environment
APIs will undergo maintenance.  We will bring the networking API during this
change.
 When the API is started back up, router failovers may occur.  We do
not expect prolonged disturbances as a cause of this maintenance, but shorter
network outages may occur.
Severity: 3. Low impact.
Elbilforum admin
Forumet skal flyttes til en ny server.
Forumet vil da være utilgjengelig i den tiden.
Vi kommer tilbake med info om når dette blir gjennomført
