Brammo MC
Startet av GRS, søn 23. okt 2011, kl. 00:07
GRS
Mer morro og bra nettside! :) : http://www.brammo.com
MYE billigere enn Sora. 14 000 dollar for verstingen :)
160 km/h og 160 km range.
TM3P sort/sort
Og 10000 USD eller 55000 NOK for Empuls'en på bilde.
Det er mindre en Vectrix'en min.
bosonic
Endelig noen som har skjønt det:
sykkelen er utstyrt med gear og clutch. :)
The 2012 Empulse has a 6 speed transmission as standard equipment. The Integrated Electric Transmission (IET™) - IET™ is a mechatronic propulsion unit that emulates the feeling and performance of a traditional internal combustion engine, with a specially developed electric motor, clutch and gear shift, that enables the 2012 Empulse to accelerate hard from the line up to a high top speed, something that is just not possible to achieve with a single ratio electric motorcycle.
e-max
Har stått på pre-order listen for deres Empulse, siden Juni 2010 (snart 2 år) og informasjonen fra Brammo er fryktelig dårlig. Leveringsdato skyves kontinuerlig 6 mnd fremover hele tiden. Tror nok også at de bommer kraftig på rekkevidden - eller jo, ved 45 km/t. Men hvis eller når den kommer (og tallene stemmer)så høres dette ut som en bra og gøy sykkel.
Tesla 3 RWD 2020
Peugeot ION 2011
E-Max el scooter 2009
flux
Electric motorcycles: finally here.
"The Empulse is simply a more pure experience than any gasoline-powered bike could ever be. It steers incredibly quickly, flicking into a corner or through a chicane like a much lighter, much more aggressive bike. Think supermoto fast, but unlike one of those bikes, it's absolutely stable once you're leaned over. Doesn't matter what you do it it in a corner — brake, accelerate, bounce around, drag the peg, hit a rock — it just stays absolutely planted."
"The Empulse is absolutely as involving as its ICE predecessors, adding a level of feel they could never have.
Riding along following Brian on the Triumph, Eric hangs back to ride next to me for a second. "Damn that thing's annoying, huh?" Both he and I were happier on the Empulse, it simply feels like a more evolved motorcycle, no caveats needed. Electric motorcycles: finally here."
http://hellforleathermagazine.com/2012/08/brammo-empulse-the-electric-motorcycle-has-finally-arrived/
