Converting a Think City to J1772 standard
Startet av Frederic, søn 17. jul 2016, kl. 17:43
Frederic
Hello,
I have installed a nice charging station at home supplied with J1772 connector.
I would like to convert my Think City and my PCS to this standard.
I have managed the mechanical interface so far but I have some doubts regarding wiring and hook up.
Has anyone done it yet ?
Regards
stradivaria
Hi,
I think I could help you with this.
Call us: www.elbilmek.no
Ask for Raimondas +47 45671127
Jobber som elbilspesialist hos www.elbilmek.no
Stromskap378V
Bonjour
TH!NK AC charge inlet, connector, wiring, harness.
Grüße und viel Erfolg
TH!NK City / Okt 2011  Standort: Deutschland / Tyskland- Berlin
YYCAD2MC4AU ... (25kW Motor, EnerDel-Batt., 2010 Finland)
Do not speak norwegian. For translate I use maschine translators.
Operativsystemet Linux_openSUSE og Debian)
Stromskap378V
Extension
To set a better image definition/ clarify.
Frederic
BauDemo
Congrats!
Did you by any chance made more photos of the process of conversion?
Is this Gen1 or Gen2 car?
If it is a Gen1 car - do you get a faint glow of the plug symbol even though the car is not plugged?
Do you have a resistor mounted in the inlet?
Frederic
Hello Baudemo,
This is a Gen2 Li-Ion
With the litterature provided by Stromskap378V it was easy !
Beside desoldering the old Think connector on the car, I had to modify the plug support plate. I had to drill aditional holes to move the plug 6 mm higher and a few mm towards the back to allow the door of the plug to open on a wider angle.
No additional resistor, nothing !
On the EVSE side I cut the plug from the cable and soldered the plug with the cable accordingly, no issue except that now it is allways in boost mode (Max Amp)
regards
BauDemo
Thank you for the details!
Yes, Gen2 is straight forward.
I did a conversion of a Gen1 car with Zebra to Type 1 inlet, and will have to revisit this soon.
