New options for Europe
Startet av tk74, tir 09. apr 2013, kl. 13:54
ebbrey
#435
Sitat fra: Celter på tir 06. aug 2013, kl. 17:13
Hentet fra Teslamotors.com: " this is what I learned from the rep at the SM showroom:
- sound system has been completely redesigned from the previous $950 option which is why the price went up dramatically (I am still not convinced of this one -- may require a call to TM). There were no cars in the showroom yet with the new sound system.
Det virker som dette fremdeles er noe uklart.  :-\
Når det gjelder interiøret, synes det som "extended leather" er en ny opsjon. Igjen hentet fra Teslamotors.com:
So this is the e-mail response I received from Ownership regarding the difference between the new and old leather options:
The leather option you purchased does not include the new extended leather trim option; the dash panel, armrests, and air bag cover are synthetic. You are correct, the back of the seats and lower dash are not leather as well.
Også hentet fra TMC: "A sales associate in LA said the the new sound system has speakers that are now not built in-house."
Her er diagram over lydstudiopakken:
Kilde: TMC
11/2013 - 2018 Modell S
Bestillt Enyaq Sportline 80X alt unntatt bagasjeromspakke og Canton
Kallagtunet
Noen andre klipp fra de samme forumene over there:
"I have been told by multiple reps (4 different ones so far) now that the premium sound has NOT changed. They each gave me the same line: "We were way undercharging for it before." They just improved the language"
"I would just like to add that 90% of the "new options" are actually nothing more than the old options offered at higher prices. For instance, the Sr. Delivery Specialist who I was put in touch with by Jerome Guillen, VP of sales and support, as well as another knowledgeable DS told me clearly that the new sound package is identical to the old "studio" package but simply re-named and re-priced to better reflect its value. Same goes with the air suspension - new name, same product as before."
Dvs det eneste som er sikkert er at dette ikke er sikkert og at Tesla fortsatt sliter med internkommunikasjon ...
ebbrey
Sitat fra: Kallagtunet på tir 06. aug 2013, kl. 19:11
Heh.. Hvis du HAR bestillt er svaret: Uendret. Hvis du IKKE har bestillt er svaret: Alt er nytt!
Woods
Ser man kan velge mellom performance og standard seter, noen som sitter på mer info ang dette?
ebbrey
Sitat fra: Woods på tir 06. aug 2013, kl. 19:14
Ja du kan nå bestille bilen der borte som vanlig S85 og få samme utseende på setene som de som er standard på Performance utgaven uten å kjøpe performance.
Dr.Ling
Er det noen av dere som har vært med på noe slikt før? Jeg mener, å kjøpe ny bil, og stadig må følge med om en får det en tror en har bestilt. Kanskje det er helt vanlig med andre bilmerker også?
Tesla skryter av at direktekjøp er så mye bedre enn å kjøpe fra forhandler, men bullshitfaktoren fra selgerne er jo minst like høy... og skaper full forvirring.
Jeg hadde jo regnet med at lys og sånt ville være forskjellig fra USA, men må si meg veldig skuffet over at vi ser ut til å få billigvarianten av de bakovervendte barnesetene. Endringen er kanskje ikke så stor, det er bare noen fake skinnlapper som er borte, men det visuelle inntrykket går fra å være racingstoler for barn til hjemmelaget benk i tøy.
P85, P2206 (bestilt 05.12.12), INVOICE 0428 (07.05.13), VIN 16899. I produksjon 20.09.13, ferdig 27.09.13. fikk bilen 06.11.13 :)
ebbrey
#441
Sitat fra: Dr.Ling på tir 06. aug 2013, kl. 23:17
Jeg må si meg enig med deg. Det har vært noen endringer i år, endringer er greit nok. Men ikke gi beskjed til alle kunder om endringene er vel der det største problemet ligger. Og heller ikke "gjøre opp for det". De har en setning at "alt kan endres" helt nederst på spec siden. Og det er vel slik det er om man vil ha bilen. Så svaret er nok nei, aldri måtte følge så nøye med på en handel noen gang. Men så blir det litt ekstra sårt når noe endrer seg da det er snakk om mer enn tilbehør til en mobiltelefon her.
Og som du skriver endringene på barnestolene er ikke store. Men det er jo ikke de du bestillte. En heads up hadde vel vært greit. Noen her kommer jo til å få bilen levert og få "sjokket" når de henter den.
TS
Utfordringen er vel at de fleste som jobber i Tesla er nye i firmaet , rekruttert sjapt, trygt og billig..De færreste har erfaring fra bilbransjen eller tilsvarende.
Og de som har vært der en stund er ikke vant til tempoet ..
En en Apple holdning på toppen av det, vips ...
Når det gjelder barnesetene, så setter jeg pris på endringen.
(ikke pga utseende )
Sannsynligvis fikk de ikke godkjent bilen i EU med de gamle. Jeg syntes de virket direkte farlige med minimalt polstrede metallstenger på hver side av de smale hodestøttene... Her vurderte jeg en modifikasjon, men det ser ut som det er ordnet  :D
Så får vi heller stikke i innom en salmaker for å få delskinn..
rEVolusjonen startet 15. oktober 2013
Des 14 SOLGT med sorg:
Model S85 - Dolphin Grey (foliert) , sort skinn, 3.rad barneseter og Morbær tre (love it...)
Sikkerhetspakke, lyspakke, Techpakke, luft , p-sens, ..
VIN 186XX
Des 14: Bestilt 2015 model S85D - Juni 15: Solgt
Des 14: Kjører Leaf 2012 med moderat rekkeviddeangst
Konebil
Juli 2015:
Kjøpt ny 15`Outlander PHIEV Instyle+ som midlertidig bil til ny 2016 Tesla ankommer...
(I en eller annen versjon..)
Oktober 2016: venter S90D med alt, håper på FaceLift ..
Sitering av TS sine poster utenfor elbilforum.no tillates ikke uten samtykk
D.O
Sitat fra: svimtapp på tir 06. aug 2013, kl. 17:57
Hvis det er kunstskinn på dash, armlener osv, hva mener de da med " Skinn i stor utstrekning." som det står i beskrivelsen av interiør? Det tyder jo på at det bør være annet enn skinnseter?
Ja det lurer jeg også på, bestilte en P model mye pga interiøret var oppgradert. Bilen jeg prøvde (blå P)hadde skinn. Hvis det kun er setene så burde dette bli opplyst om. Seter er seter, interiør er seter med mere(dash,dørsider o.l) Model s er i såfall første bil jeg har hørt om som bruker denne betegnelsen om kun seter. Og hva i pokker er "skinn i stor utstrekkning" hvis det kun er på setene? Og dessuten har P modellen samme data/tekst som P signature på nettsiden når det kommer til interiøret.
Synes Tesla folka i Trondheim og via mail har vært topp, men informasjon fra nettet er helt elendig. Mye endringer og ingen info. Må si at jeg har mistet litt av Tesla fanet i meg i det siste.
Nå:Mazda mx30, Proace electric,  Rav-4 , BMW M5, Fox Mustang og Haibike el sykkel
Bestilt/reservert:
Cybertruck
Før:
Hyundai Kona
Model 3 (kansellert for Kona'n)
Model S P85 -13
Model X-reservert (Ble dessverre kansellert til fordel for P85D)
Model P85D(solgt, ble ikke fornøyd)
Sitering av D.O sine poster utenfor elbilforum.no tillates ikke uten samtykke.
_Hans-Petter_
#444
Fikk svar på en del spørsmål for noen timer siden av Heidi.
Dashbord og dører kommer med syntetisk skinn slik som på de fleste biler, men fordi du har nappa interiør vil partiet under vinduet også være i nappa skinn material.
Du vil da også ha Alcantara i taket innvendig.
Jeg har full forståelse for at det kan være litt forvirrende inn i mellom. Vi jobber nå hardt med å forbedre My Tesla og våre programmer slik at det blir så enkelt som mulig for kundene våre. Dette er en liten transitt som tar litt tid. Vi takker derfor stort for forståelsen og tålmodigheten.
Det er så bra å høre at du gleder deg, det kan jeg love deg at vi også er.
I morgen braker det løs og vi er veldig spente. Heldigvis øker vi antall lokaler i norge og mer og mer plass er tilgjengelig. J
Gode nyheter er det også at Nokian Hakka har blitt bekreftet og det kan du velge å legge til din bestilling når du blir kontaktet av din leveringsspesialist nærmere levering
VIN 15301
Levering 30 september 2013
solgt 12 mars 2017
VIN177908
Levering 18 mars 2017
Balrog
Tesla S P85 2013, Tesla Model S 75D 2017, VW E-Up 2020, Renault Zoe 2017, Hyundai Kona 2021, MG ZS EV 2020
Energica Experia elektrisk MC 2023, Zero SR elektrisk MC 2017
D.O
Jepp, det var oppklarende  :)
Bestilt/reservert:
Cybertruck
Før:
Hyundai Kona
Model S P85 -13
RunarBT
Får me alcantara i tak på vanlig performance så er det ein stoor overraskelse og pluss, all den tid dette blei droppet fra us performance for måneder siden?!? Er enda i tvil eg da, trur det ikkje før eg ser det.
OW
#448
Sitat fra: RunarBT på ons 07. aug 2013, kl. 07:54
Ja, vi skal få alcantara i taket på Performance. Det har jeg også fått skriftlig bekreftet fra Heidi, og var en stor grunn til at vi valgte Performance. De andre tingene i Performance pakka var også viktige selvfølgelig, men kona var nok mest opptatt av alcantara da hun syntes det ga en mye lunere og bedre følelse i kupeen enn standard taktrekk.
Det ble produsert noen Performance i US som kom uten alcantara i taket. Dette var vist en feilproduksjon. Med nye options i US så vil det jo ikke lenger være standard, men i Norge er beskjeden jeg har fått at alcantara er standard for de som velger Performance (inntil videre?).
Model S P85 perlehvit, 19", sort og CF interiør, CF spoiler, panorama, tech-pakke, parkeringssensor, lydstudio, sikkerhetspakke, lyspakke og pakkehylle.
RunarBT
Sitat fra: OW på ons 07. aug 2013, kl. 08:05
:-D gleder meg om mulig enda meir til 28.august
