RLEC data strings only return zeroes in CommTool for 2 RLECs
Startet av Myles Twete, ons 11. nov 2026, kl. 05:32
Myles Twete
Most common RLEC issues I have seen are (1) unreal cell voltages (e.g. near zero or near 5v), (2) temperature reading that is out of whack, (3) no CAN response at all.  Additionally, RLEC cell voltage input circuitry can be leaky either always or only when powered.
Yesterday, a THINK user who replaced 7 of his 16 RLECs reported that 2 of the other RLECs in the pack (which reported correctly earlier) now report ALL ZEROES for data in CommTool.  He says that CommTool reports the ID# for each of these 2 RLECs but all the other data shows 000000000.
Has anyone else seen something like this?  Bad RLEC, CAN issue, Driver issue, termination issue or ????
Thoughts?
-Myles Tveita, Portland, Or.
worry
I've only seen that when the ribboncable from the block is uncoupled. Did that on purpose to verify RLEC ID's on the right place in the battery.
He should try to move RLECs around to see if the fault follows RLEC or block.
Think lithium
Warlock
 :+1:
What Worry says.
There could be some errors with the ribbon cable (echoes due to lacking termination as you mentions for instance)
I've not yet been able to determine where the terminators for the secondary/internal Enrdel CAN-line are located...
Myles Twete
Tusen takk min Think venner!
I suspect you both are correct and that he has wiring issues and/or bad line termination on CAN bus.  I passed on your comments to him.  Unfortunately, I don't understand his response.  He indicated he has had wiring issues, but that even after improving things and swapping RLECs he still had the same issue.  Then he says he reprogrammed the 2 RLECs#0/1 as RL#2/3 and afterwards the contactors clicked.  I can't tell from his email if things are working right or not.  All this is after his replacing 8 RLECs and 1 MLEC (which was damaged).  Hopefully I will hear that it all works correctly now...
