Skal kjøpe Zoe 50 tips/fallgruver?
Startet av Andreas84, fredag 08. august 2025, klokken 10:42
Andreas84
Jeg skal kjøpe Zoe 50. Er det noe jeg burde være obs på som er vanlige feil ved denne modellen?
Sikter mot iconic
Hvilken modell hadde adaptiv cruisekontroll?
minibiti
None of the ZE50 have adaptive cruise control, unless it came after the first models in 2020.
I would also recommend updating the BMS to the latest version if possible and not done already.
One thing that is a bit weak on the ZE50 is the "lenkearm" (if I remember correctly the term in Norwegian).
The best is to test drive the car and see if you feel/hear something suspicious, on bad roads as well :)
2022 Megane Iconic (Aug 2024 - present)
2020 Zoe Intens R135 (Jan 2020 - Aug 2024)
Andreas84
Takk 🙂
Jeg mener å ha lest at den har forskjellige motorer (hestekrefter).
Dette er en 2020 intens modell med 136 hestekrefter.
Jeg husket feil ja, det var visst antikollisjon noen hadde (https://elbilforum.no/index.php?topic=64409.0)
minibiti
The ZE50 Intens and Iconic have 136 hp engines.
The Life and Zen have 100 hp engines. And also small screen in the middle above the gear shifter.
