Oppdatering 4.0/4.1 til 5.xx
Startet av MinID, ons 16. jul 2025, kl. 09:10
MinID
Endringer oppdaget fra 4.0 til 5.4.3 lånt fra tysk side:
" Other infotainment home screen: It used to be the 1. Edition, now it's from Harman Kardon.
- Other logo in the head-up display: VW instead of ID.
- Lane change assistant does not stop the lane change immediately when steering, but has a significantly greater tolerance when you start moving with the steering wheel during the change. The travel assistant also seems to be less restless when steering, but that may just be my perception.
- New wellness app
- Locking and unlocking possible via the smartphone app
- Remote parking possible with the Park Assistant app
- Vehicle shortcuts provide additional functions of the wizard, and the screen displays 8 instead of 6 buttons (the speed warning is one of them, but still requires 2 clicks, but is a larger button).
- Auto widget does not show more range and consumption, but only the range.
- The steering wheel heating responds much faster, no more delays.
- The sitting massage takes into account the program set on the screen and the set time.
- Seasonal animations.
- The HUD looks completely redesigned, with new animations and supports Google Maps in Augmented Reality.
- New battery care that adjusts the charge to the outside temperature.
- The user interface has been revised: the fonts are different/larger in many places, many settings have been moved to submenus.
- New app for updates describing the versions of individual apps.
ID4 GTX 4 motion, 2024, sw 5.4.3 løftet på verksted fra sw 4.0
Solgt: ID4 GTX 2022, Ioniq5, Id4 first, Hyundai kona, Kia Soul
magfred
Sitat fra: MinID på man 22. sep 2025, kl. 11:45- Remote parking possible with the Park Assistant app
Denne, pluss at bilen husker å senke høyre sidespeil ved revers (hvis du har aktivert dette), fungerer visstnok ikke for alle. Mulig det er noe ekstra hardware som må være på plass, evt at det f. eks kun fungerer med ID.7 og ikke 4/5.
Ellers mye snacks som blir fint å få tilgang på.
Peugeot e208 GT Pack
Volkswagen ID.5 GTX Facelift
Tidligere Volkswagen ID.4 1st Max
MinID
Sitat fra: magfred på man 22. sep 2025, kl. 21:31
Må nok ha seter med minne for at dette skal fungere. Mener det er slik pga at minnetasten må eksistere. Ser ut til å fungere hos min id4.
magfred
#19
Fra og med idag starter oppgradering til 5.6.3 for ID.4/ID.5/ID.7, kode for aksjonen er 57K5.
For å sjekke om din bil er berørt kan du legge inn din VIN her: https://www.dieteren.be/en/recall
Ser at aksjonen er pga dørhåndtakene, men regner med at alt som var gjort i 5.4.3 oppgraderingen også er med i 5.6.3.
Noen tidsestimater for oppdatering hvis alt går på skinner, tatt fra et tysk forum:
ID.4/ID.5/ID.7 med fabrikk-ID. Programvare 4.x Varighet: 05:30 timer
ID.4/ID.5/ID.7 med fabrikk-ID. Programvare 5.0 GD9 Varighet: 04:30 timer
ID.4/ID.5/ID.7 med gjeldende ID. Programvare 5.4.3 (tidligere 4.x) Varighet: 03:50 timer
atrus
Noen som har erfart om noen innstillinger som er tilbakesatt?
magfred
Min hadde kun radiostasjoner nullstilt, ellers var alt som når jeg leverte bilen.
Hwal
Hei, jeg har id.4 2025 modell. Jeg ser henvisning til versjonsnr f.eks. 5.4.3 her på forumet.
Hvor kan jeg finne versjonsnr for min bil på dette formatet? Når jeg går inn på Systeminformasjon i Infotainmentsystemet, så står det Programvare: 3748.
Kan noen forklare sammenhengen her, hvor skal jeg finne versjonsnr på det formatet som ofte refereres til her på forumet?
Takker, Helge.
ThorEgilL
Sitat fra: Hwal på fre 26. des 2025, kl. 21:17Hei, jeg har id.4 2025 modell. Jeg ser henvisning til versjonsnr f.eks. 5.4.3 her på forumet.
Takker, Helge.
Du finner det under ID. Software i menyen.
Fikk nettopp oppdatering fra 5.4 til 5.4.0 Noen i VW har ikke helt skjønt hvordan programvareversjoner skal nummereres.
Hwal
Jeg fant det nå!
Sjekket nettopp, og jeg har 5.4.0 .
Takk for hjelpen!
