I have commited v2.0 of vehicle_thinkcity.c tonight.
SMS is migrated from the standard handler to the vehicle-file. This makes it possible to create our own SMS-commands.
Currently two commands are available:
STAT: prints Charge state,AC-voltage/current (during charging), SOC, batt temp, PCU temp, aux batt voltage, traction battery voltage and current.
DEBUG: prints flags/variables like SOC, Charge Enable, Open Circuit Voltage Measurement, End of Charge, Doors1 (PCS connected) and Charge status.
HELP: This command should return a list of available commands ("STAT, DEBUG, HELP"), but ironically it's not working... I have tried a lot, but had to skip it for now.
I'll guess my changes will be migrated to the master project within a day or two
Attached is my latest hex-file which I have tested OK (all except SMS "HELP").
@habazot:
Regards to the RAC. If it's working and your airbag lamp if functional, you should leave it. There is no support for the RAC and it's only purpose is relaying SRS OK signal to the instrument panel.
If possible, try to release the GSM and GPS-connectors from the RAC for OVMS-usage. You'll need some very long hands, a flexible spine, and lot of patients
