Designing new RLEC boards, any interest?
Startet av Zuikkis, torsdag 17. august 2023, klokken 08:18
Zuikkis
Sitat fra: babjerke på tirsdag 23. juli 2024, klokken 12:42Hi
What is the current status of the new design for RLEC modules? I am interested to replace old cards both for Think use and standalone solar batteries use. I can also help with HW/SW development.
I also need a new TIM module...
/Bård
Thanks for your interest. I'm again looking into this, as my Think is again broken and this time I don't have enough RLECs..
I can't give any schedule, though..
babjerke
Hi
I am very interested to push new RLEC cards forward. Some time ago I looked at using modern ICs to make a double RLEC with very few components - it can be realized very cheap and compact. It could be interesting to replace the MLEC also. Lets make an open source project to solve this!
Sort 2010 Lithium Think - 21000 km så langt (2014); 53000 km i 2016; Bestilt Tesla Model X - RN1516 172 000 km så langt (2024); Bestilt 1 stk Model 3 130 000 km så langt (2024)
Zuikkis
Sounds good. :)
I have the PCB form factor measured already for the double RLEC, see the combiner board in previous page.
Double board does make sense. The two battery modules in same casing are always connected the same way in series, so they can be handled by a single 24 channel BMS.
babjerke
I am still on holiday but I found my KiCad test files for the double RLEC module based in Maxim MAX17823H chip. It was called repRLEC (replace RLEC).
Zuikkis
Oh, that's great!
I'm still trying to decide which chip to use..
babjerke
I think the ST part 9963E is maybe better - more NTC inputs (7 vs. 2), maybe a simpler isolation transformer interface solution between the devices - and a little cheaper. Are there other candidates out there?
The MLEC function should be included in the base design - a Teensy 4.0 with multiple CAN busses can be the interface to the MCU. Which functions has the MLEC: control prechange resistor, voltage/current sense, main contactor operation, other safety functions?
Zuikkis
#21
ST9963E is still over 10€ in small quantities. There's alternatives like Texas BQ76952 which costs under 5€ (2€ at high quantity) and still supports 16 cells and 9 external thermistors + 1 internal!
But there's some downsides. Absolute maximum 100mA balancing current, recommended ~60mA and even that has thermal limits. But you can add external FETs to add more current, and that doesn't really cost much. And in a "working" battery even the 60mA should be enough, if no cells are self-discharging..
Other downside, this chip is not daisy-chainable, but it's still relatively easy to use optoisolators etc to connect the SPI bus. And the internal connection in dual RLEC doesn't necessarily need isolation, if we trust that the two battery modules are connected in series.
About MLEC, I think I don't want to do it at this stage. It's much more bigger step than RLEC. MLEC has a lot of safety functions like insulation resistance measurement etc, those things must work or there's a big risk.. Also MLEC software would be much more complex as there's a lot of CAN messaging. RLECs only need to respond to a few messages, which I'm already familiar with.
Even with RLECs, there's some choices to be made. At least one RLEC must have a processor that handles the CAN messaging and then communicates with the BMS chips. Then the other RLECs could be dumb, with only BMS chip.
But the price of current microcontrollers is so low that it probably makes sense to have eight identical dual RLECs which each have CAN interface and a processor.. That way it's even possible to mix original and new RLECs.
Zuikkis
Anyone know if there's any way to reach the battery internal CAN bus from outside? Directly it's not possible, but perhaps we can persuade MLEC into sending some custom message?
Would need some method to update firmware on these replacement RLECs without disassembling the battery. :) Not that I don't trust my programming skills.. :)
Zuikkis
I just ordered a first batch of boards from Elecrow, 16 pieces. So enough for two cars as each card has two RLECs.
The design allows "master" and "slave" cards, masters have 16pin CAN connector like standard RLEC. Then you can daisy chain upto 7 slaves after that one master. So only one master needed in each car.
However since the assembly start cost is so high (~250€) I now ordered only master cards. They can easily be connected as slaves too for testing, and also allows to test a setup with 8 masters and no slaves (only CAN bus connection).
It should be possible to mix old and new style RLECs, if only a few are needed. Then again, it might make sense to replace all and sell the remaining working old RLECs..
The price of the card is much higher than I anticipated originally, would need to order much bigger quantities to make it lower. The net price of these 16 cards is about 110€ piece, and that only contains the SMD parts (no connectors). I found the 42pin battery connector on Mouser but it's 7€ piece and you need two per card.. Regular pin header is cheaper but has too short pins and has no locking mechanism. I perhaps try to salvage some parts from my broken RLEC cards, but the connectors are difficult to remove.
Also I spent something like 20 hours on the hardware design, and I still haven't even started on the software.  ;D
I will eventually sell these on my webshop but I'm afraid what the price will be.
Warlock
:+1:
I might order one.
Still wondering a bit about the cost tho, PCBWay and similar has reduced cost for card production quite a lot the latest years, so are the components the costly parts for these cards, is it quite large, or is this production done by a local firm, or something else?
Zuikkis
#25
Sitat fra: Warlock på tirsdag 10. september 2024, klokken 20:18:+1:
I might order one.
Boards and assembly are done by Elecrow, a chinese manufacturer.. It should be one of the cheapest.
Most of the price comes from the components. And also the assembly price is about 250€ total for any amount of cards, so now it plays quite big role when only 16 cards are made.
PCB is quite big (315*100mm) but it still only costs about 4€.. It would have been easy to split in into two, but I figured the connectors and wiring between the cards would easily be more expensive.
The slave card is quite a bit cheaper.
In the meanwhile, I learned that it's actually quite simple to remove the connectors from RLEC cards using a heat gun.. :)
Zuikkis
Just got photos from Elecrow, they have finished the boards and are shipping now. :) Then I can start on the software..
babjerke
Zuikkis
Sitat fra: babjerke på tirsdag 15. oktober 2024, klokken 23:37The card looks nice - which IC did you go for?
It is the ST9963E.
I draw a schematic with the much cheaper BQ76952, but turns out once you add the isolation components and external balancing fets, the price is almost the same and it's much more complex circuit.
Zuikkis
#29
Some progress. :) Coding the stm32 program was much bigger task than I expected, but I think it's pretty much working now. I plan to release at least the software and the schematics into github soon.
There was a few hardware bugs (design faults).. CAN bus has H and L reversed, but they can be cleanly fixed in the ribbon cable connector on board side. Then there was a mysterious measurement error in one of the cell voltages.. I feel this is a documentation error in the datasheet, I asked about in the ST forum but no one has replied:
https://community.st.com/t5/power-management/l9963e-in-12s-setup-middle-cell-shows-too-low-voltage/m-p/756642#M12975
Anyone my fix seems to be working and was easy to implement on the existing boards, just connect two adjacent pins with a solder blob.
Next batch of boards will obviously have these fixes included.
(open picture to new tab to enlarge)
Here are the boards in place. I decided to use the six original RLECs that were still functional.
The Double RLEC in bottom left is the master. It is the only one connected to the original CAN bus (ribbon cable). Rest of the Double RLECs are daisy chained using the L9963E two-wire isolated SPI bus. The master card listens to CAN messages and pretends to be all ten RLECs himself.
The daisy chain connecting cables are the 4pin cables that normally connect two RLECs.. I thought everyone has these laying around. If you have two broken RLECs you will have one cable also. :)
Any configuration of RLEC / Double RLEC can work; you can have any amount of "old" RLECs and you could also have multiple master Double RLECs..
The black box is a Raspberry Pi that is connected to the CAN and also has UART connection to the master RLEC which allows it to flash new firmware into it etc. So I can remotely debug and develop the software inside the house while the battery is in my cold garage.. :)
Here is the RLEC data recorded by the raspberry:
Balance target 4100 mV, balanced cells: 0
Module 00    Reported: 47.70 V  Calculated: 47.70 V    34 C    Status 0x0
  T:    -3    -3    -3    -3    -3    -3    -3    -3    -3    -3    -3    -3  (  -3-  -3)
  V:  4023  3996  3965  3962  3957  3938  3962  3962  3962  3962  3986  4026  (4026-3938 =  88 mV)
Module 01    Reported: 48.13 V  Calculated: 48.13 V    29 C    Status 0x0
  V:  4030  4013  4013  4001  3996  3999  3999  3977  4008  4030  4033  4035  (4035-3977 =  58 mV)
Module 02    Reported: 48.31 V  Calculated: 48.31 V    27 C    Status 0x0
  V:  4026  4030  4030  4033  4033  3999  4021  4033  4035  4033  4011  4030  (4035-3999 =  36 mV)
Module 03    Reported: 48.45 V  Calculated: 48.47 V    29 C    Status 0x0
  V:  4035  4038  4038  4038  4038  4040  4038  4040  4040  4040  4040  4040  (4040-4035 =    5 mV)
Module 04    Reported: 47.99 V  Calculated: 48.00 V    30 C    Status 0x0
  V:  4030  4030  4021  4018  3977  3989  3989  3965  3984  3991  4001  4008  (4030-3965 =  65 mV)
Module 05    Reported: 48.02 V  Calculated: 48.02 V    27 C    Status 0x0
  V:  4006  4008  4006  4008  4006  3986  4008  4006  4016  4021  3994  3950  (4021-3950 =  71 mV)
Module 06    Reported: 48.31 V  Calculated: 48.33 V    25 C    Status 0x0
  V:  4023  4016  4023  4026  4023  4023  4006  4030  4038  4038  4040  4045  (4045-4006 =  39 mV)
Module 07    Reported: 48.29 V  Calculated: 48.32 V    29 C    Status 0x0
  V:  4016  4028  4028  4033  4030  4033  4035  4021  4035  4033  3999  4033  (4035-3999 =  36 mV)
Module 08    Reported: 48.35 V  Calculated: 48.36 V    31 C    Status 0x0
  V:  4030  4033  4033  4026  4030  4033  4030  4026  4028  4028  4030  4035  (4035-4026 =    9 mV)
Module 09    Reported: 48.13 V  Calculated: 48.14 V    30 C    Status 0x0
  V:  4038  4021  4018  3986  3991  3994  3994  3994  3994  4035  4035  4038  (4038-3986 =  52 mV)
Module 10    Reported: 48.37 V  Calculated: 48.39 V      2 C    Status 0x0
  T:    -1    -1    -1    -1    -1    -1    -1    -1    -1    -1    -1    -1  (  -1-  -1)
  V:  4033  4028  4028  4028  4035  4035  4035  4033  4033  4033  4033  4033  (4035-4028 =    7 mV)
Module 11    Reported: 47.80 V  Calculated: 47.91 V      2 C    Status 0x0
  V:  4030  3979  3977  3974  3972  3969  3908  3989  3991  4038  4038  4043  (4043-3908 =  135 mV)
Module 12    Reported: 47.82 V  Calculated: 47.71 V      4 C    Status 0x0
  V:  4033  4035  4033  4038  4035  4035  4035  4035  4033  4038  3328  4030  (4038-3328 =  710 mV)
Module 13    Reported: 47.35 V  Calculated: 47.84 V      3 C    Status 0x0
  V:  4008  4018  4021  3977  3974  3967  3969  3969  3965  3967  3972  4035  (4035-3965 =  70 mV)
Module 14    Reported: 47.54 V  Calculated: 47.54 V      3 C    Status 0x0
  V:  4035  4033  4008  4006  4006  3413  3999  4006  4006  4008  4011  4011  (4035-3413 =  622 mV)
Module 15    Reported: 48.01 V  Calculated: 48.14 V      2 C    Status 0x0
  V:  4030  4006  4008  3996  3996  4004  4006  4018  4006  4023  4018  4028  (4028-3996 =  32 mV)
06.01 15:40: Cell (3328-4045)=717 mV,  Temp (-3--1),  Pack 48.47 V,  Status 0x0
Modules 00-09 are Double RLECs, 10-15 are original. There seems to be some difference in the measured temperatures (-3 vs -1) but I don't think that's critical. Also the "board temperature" in the top row is chip internal junction temperature for the Double RLECs, that's why it's so high (~30C). MLEC shouldn't be interested in those..
There is some severe imbalance in modules 12 and 14.. I will have to remove those batteries and charge (or replace) the low voltage cells.
Next step will be to wire up the HV cables and connect the battery to the car, to see if MLEC likes what it's seeing.. I can also listen MLEC<->RLEC communication with the Raspberry. I will made extension cables so I can connect the battery to the car without moving it any closer.
