Studs on E-Niro?
Startet av aileron, tir 02. jun 2020, kl. 21:34
aileron
Sorry for not writing in Norwegian, I'm still learning... (feel free to reply in Norwegian though) I wonder if any of you use studded tires with their E-Niro? And if so, how are the studs affecting range? I'd assume that low temperatures have a bigger impact on range than studs, but I'd appreciate to hear about any experience you may have made...
meitran
I have no experience with studded tires on my ev's. But the studded tires will obviously be less energy-efficient then non-studded ones. Alot of drivers use studded tires even though they most likely would get the job done with non-studded ones. The only reason for getting studded is in my opinion if you regulary drive on wet icy roads. Not what you are asking about, but just my point of view 🙂
