Getting some heat while charging
Startet av minibiti, fre 03. jan 2020, kl. 15:15
minibiti
I have read/seen many places people complaining about not being able to use the heater in the car while it is charging. But I also seem to remember that using the pre-conditioning is a possible work around.
So I finally tested today with my R110 :)
And indeed it works! I started the charge and then while sitting in the car I pressed the button on the keycard and after a little while, heat came out of the vents.
I guess it is the same if one uses the app.
Can you guys who have a earlier model confirm that it also works for you?
Oslo
2022 Megane Iconic (Aug 2024 - present)
2020 Zoe Intens R135 (Jan 2020 - Aug 2024)
hsa77
Jepp, fungerer fint på min 2017 modell, mener også å huske at det virket på min 2015 modell. Uansett er dette en workaround på en dustete begrensning i bilens software, hvorfor mener Renault at man skal fryse mens bilen lader?
2017 Renault ZOE Intense ZE40
minibiti
"Dustete" indeed, I am with you on that one...
Looks like the ZE50 has the same limitation from the test videos I found.
I will test more when I get mine next week.
Oslo
Trine2
I have heard that the button on the keycard does not exist for the ZE 50
minibiti
Yes me too.
But worst case you can use the app to do the same :)
Oslo
hsa77
Eller programmere forvarming 15 min frem i tid på skjermen i bilen.
chriso89
Håpløst av renualt.  burde vært enkel oppgradering for å tillate varme uten omvei
