7,2 kwh ladestopler for Zoe
Startet av Jørgen209, ons 01. jan 2020, kl. 20:25
Jørgen209
Heisann,
Jeg planlegger å investere i en Zoe, og har hørt at den ikke lader på 7,2 kwh ladestolper. Men kun 22 kwh ladestopler eller hjemmeladere med 3,6 - 7,2 kwh. Er dette sant? Tenker å bruke ladestoplene til kommunen  8) Har også hørt at 12v batteriet må skiftes regelmessig på denne bilen, har noen erfaringer med Zoe her?
minibiti
The Zoe can charge on anything between 2kW and 22 kW. Some older Zoes (the Q210) can even charge at 43 kW.
All this AC.
The new Zoe ZE50 supports both 22 kW AC via Type 2 and 50 kW DC via CCS.
The only thing you have to be careful with the Zoe when you charge with AC is that the grid has to be TN, not IT.
Or have a "ladebøtte" or a transformer at home if you don't have TN there.
If the voltage is 400V or if the charger is 11 kW or higher, it is on a TN grid hence compatible with the Zoe out of the box.
The 12V battery is changed as part of the service every 3 years.
Oslo
2022 Megane Iconic (Aug 2024 - present)
2020 Zoe Intens R135 (Jan 2020 - Aug 2024)
