Model 3P winter wheels
Startet av Dario88m, ons 11. des 2019, kl. 14:33
Dario88m
Hello! Thinking to order a M3P this week... I would like to avoid the winter wheels package from Tesla with the 20 inches. I read a lot about being able to put 19 or 18 inches and just got even more confused :). Anyone that could help me to clarify what are my options?
Thanks a lot
Tesla Model 3 LR AWD Hvit/Sort (01.2020) Solgt
Tesla Model X LR "Raven" Grå/Sort
Tesla Model Y Performance Hvit/Sort-Bestilt 06.22
Tesla Model S LR "2023" Grå/Sort - Bestilt 01.21
Tesla Model X LR "2023" Grå/Sort - Bestilt 05.21
hemi
20" works surprisingly well, I would actually buy again.
this is my "2nd" season using them as I got the car early. TM3P
Dario88m
I took a model 3P for a test drive and yes they were working pretty well. Still I would prefer a 19 inches (more tires choices) and an higher profile of the tires that helps in case small sidewalk for example are covered in snow. Stupid example I know 😁. OFC in not possible I still go for the 3P anyway. Just wondering if someone managed to put smaller wheels.
På 4:55 sier han at vinterdekk alltid støyer mindre enn sommerdekk.
Det stemmer ikke for originale 18tom, da sommerdekkene har dempeskum og vinterdekkene (piggfrie) ikke har dette.
Ble overasket da jeg i vår skiftet til sommerdekk og bilen ble stillere.
Ludde
I were going thru the same dilemma.
In addition to having more tire choises i liked the idea of changing the look og the car from summer to winter.
Most 19" will fit while a few 18" will fit. It's important to ensure that the rim fit on the hub as the performance has that ekstra lip on the inner part of the hub (i'm sure you've read all about that). My local dealer made sure everything would fit, and i needed a set of spacers anyway for the winter wheels.
Went with a set of grey 8,5x19" niche targa m127 on hakka r3. As winter tires has a thicker sidewall they dont look streched at all (which was my concern) and the tire is still further out than the rim, which reduces the risk of curbing.
The clearence between the rim and the rear brakes on mine are at an absolute minimum as the brake rubbed against the balancing weights on the inside of the rim. After i moved them further in, i havent  had any issues of freezing and so on. I actually like my winter wheels more than my summer wheels as i fint the originals a bit boring now that everybody have them.
Hope this helps and good luck :)
Both our cars have 18' wheels that fit P
Black Rhino and Zito
The Zito wheels are light (8kg) and not too expensive
I am very impressed by the Continental tires and somewhat disappointed by Nokian.
Both set cost about 18 k kr each with tpms, mounted on the car.
CorsoDante
Sitat fra: Dario88m på ons 11. des 2019, kl. 14:33
Thanks a lot
Options are 20", 19" and some 18" (brakes must fit inside, check with the seller).
I opted away from the standard Tesla rims for my winter shoes, as I prefer not to drive with the same set of rims throughout the year.
I also chose 19" as opposed to 20", as I appreciate a bit more rubber during winter time (18" is however out of the question).
Enjoy the car, I'm pretty sure you'll be truly satisfied - regardless of the winter rims you opt for.
TMYP HW4 / TM3P Atom
Dario88m
Thanks for all the answers. The black rhino looks really good! I assume the have 19 as well. Where did you buy them? Probably I will get the car in February in Tesla skøyen, do you know if vianor or another shop pretty close ( dekkman I guess) could they just install a set of winter wheels?
Sitat fra: Dario88m på ons 11. des 2019, kl. 23:01
https://www.felgteknikk.no
Talk to Fabian
Dario88m
Sitat fra: knut.aulie på tor 12. des 2019, kl. 05:04
Talk to Fabian
Thank you , just realised that their workshop is just 500m from my workplace 🙂. I'll go to talk with them next week.
Dario88m
Thinking to go for 245/45 R19 if they fit , There are some good offers for neures tyres. Anyone as experience with those? 245/45R19 VINTERDEKK NEREUS NS805+
Watched a YouTube video of Bjorn saying that are pretty good.
Roy N
Jeg er veldig fornøyd med Nereus og 18"PH Turbin2 grafit fra megahjul.no.
De går rett på M3P uten fresing av hub.
Øket dekk trykk til 48 psi da de var veldig myke i mer enn +6 C.
Har alltid hatt Nokian før og var skeptisk, men de Nereus sitter mist like godt.
No Chill Mode required  :)
2023 Model Y Perf
2019 Model 3 Perf (solgt)
