RS485 communication standard Charger to BMS
Startet av BauDemo, ons 22. mai 2019, kl. 13:54
BauDemo
Is there any place where I can download/access the standard used between the charger and the BMS in the Think?
I am troubleshooting a broken charger and it would make it much easier if I can isolate eventual problems.
I can not help with such info, but a way around is to use a Renault Clio comunication card in the Charger for fault finding purposes. This card will allow charger to start charging for a second ore so even without communication.
BauDemo
Thank you - don't have such card yet.
But I have a RS485 adapter that I may try to connect and see...
BauDemo
I managed to log the messages from the BMS and published the preliminary results here for future reference:
https://www.evmonitor.info/2019/05/i-had-chance-to-log-messages-that-bms.html
I could not find a good way to easy listen to the traffic, so there will be some time before I log the messages from the charger.
Nikolay
