Sjekkliste mangler/kjente feil utlevering Model 3
Startet av coleick, fredag 13. september 2019, klokken 09:45
coleick
Det finnes sikkert linker til tema fra tidligere innlegg - uansett:
HVA er det man skal se etter ved henting av nybil på Tesla Model 3?
Det er vel greit og påpeke mangler/unøyaktigheter/ kjente feil i butikk.
Jeg har bestilt grå farge og henter torsdag til uka ; ))
Teslarius
Jeg har ikke fått utleveringdato for min M3 LR AWD enda (bestilt 30. juli), men jeg tenker å bruke denne sjekklisten når leveringsdagen kommer:
Exterior inspection
1. Check for correct vehicle body color and wheels.
2. Inspect body exterior paint for defects.
3. Inspect vehicle underside (front & rear) for signs of damage.
4. Check for any obvious body panel misalignment.
5. Inspect wheel rims for damage.
6. Inspect all glass for signs of distortion or cracks.
7. Check for proper windshield and windshield trim installation.
8. Inspect all edges of the roof glass panel and rear window.
9. Test all doors to ensure they open and close without unreasonable effort. Check paint in areas such as door hinges, that are not visible when doors are closed. Some deliveries have reported incomplete body painting in hidden areas.
10. Test opening and closing of trunk and frunk. Check paint in areas that are not visible when frunk and trunk are closed. Some deliveries have reported incomplete body painting in hidden areas.
11. Check for the towing eye under the frunk mat.
12. Ensure door windows auto-close completely when doors are closed.
13. Check for front license plate bracket .
14. Check all front and rear exterior lights for signs of internal condensation.
Interior inspection
1. Watch for any error messages on the display screen.
2. Test driver & passenger door emergency release.
3. Check all 4 windows to ensure they open and close properly.
4. Inspect interior seat upholstery, door surfaces, dash, headliner & carpets (including passenger compartment, frunk, and trunk).
5. Check left & right clothing hook operation.
6. Check all seat belts for proper operation.
7. Check rear seats for proper fold-down operation.
8. Test sound system to ensure all speakers are working (move fade/balance to all four points to verify)
9. Test steering wheel position controls to ensure proper operation.
10. Press the center of the steering wheel to make sure the car's horn works.
11. Test windshield wipers.
12. Test rear view camera.
13. Check side mirrors for proper operation of folding and position adjustment.
14. Check sunvisor operation and mirror condition.
Lighting inspection
1. Vanity mirror lights.
2. Front overhead driver & passenger lights.
3. Rear overhead left & right side lights.
4. Ambient lights
5. Driver & passenger foot wells
6. Driver & passenger door pockets
7. Rear left & right door pockets.
8. Driver & passenger door puddle lights.
9. Console middle compartment light.
10. Console rear compartment light.
11. All door latch button lights.
12. All door window button lights.
13. Steering wheel control lights.
14. Glovebox light (check glovebox opening and closing).
15. Frunk light.
16. Trunk lights (2).
17. Fog lights.
18. Headlights (low & high-beam).
19. Front park lights.
20. Front turn signal lights.
21. Left & right side turn signal lights.
22. Rear running lights.
23. Brake lights.
24. Rear turn signal lights.
25. Sunvisor driver & passenger lights.
Inspect charging ability
1. Check charge port door for proper operation.
2. Check charge port indicator light.
3. Ensure vehicle will accept a charge.
4. Check mobile charging kit. Test it to ensure it works. 4a. J1772 adapter. 4b. NEMA 5-15 120v adapter. 4c. NEMA 14-50 240v adapter. 4d. Mobile Connector with cable.
Inspect pairing connectivity
1. Test both key cards to ensure they work with your car. Keep one key card on your person in case the phone app does not operate properly.
2. Attempt to pair your smartphone to your car over Bluetooth.
C_B_
Gratulerer med ny bil!
Bare søk på ordet sjekkliste i søkefeltet øverst til høyre og flere dukker opp.
Finnes noen veldig omfattende sjekklister, men jeg gikk for den enklere typen der mest lakk, pakninger og slik ble sett over.
Å gå gjennom f.eks. mange valg på skjermen gjorde jeg ikke, fordi det tar lang tid + at dette vil det vil være enkelt å få fikset på garanti senere. Håper dette med lakkfeil har blitt mindre av nå.
I mitt tilfelle fant jeg: Pakninger som lå feil i dører/rundt glass og riper. Greit å ta bilder av slike feil og dokumentere slik at de ikke sier senere at du fikk f.eks. ripene etter egen slitasje.
Grå farge er flottest selvsagt :+1:   ...fargen passer med de grå felgene med Aero Wheel Cap Kit'et.
