Think2010 lithium - Charging Problem
Startet av runeno, man 19. nov 2018, kl. 22:09
runeno
Hi,
Below I have attached diagnostic information from CommTool v2.1. Previous owner has changed 12v battery, PCU and DCDC card and probably much more. I have deleted all malfunction codes using CommTool. However, there is still an active error code. In my opinion, this is because the lithium battery has not been charged since Mai 2018. So now, the charger will not starte charging because the cells have to low voltage. Is it possible to adjust the limit (is that the delta?) below the current voltage in the cells, below 2.4951 volts. The CV_Delta is now set to 2.9688. I think this is the reason for the charging is disabled.
Is there any experts here that can give me hints on how to fix this?
runeno
The problem was a RLEC card. This is now changed, and now the car is functional again. It both charge and drive.
Kind Regards
Rune
mohpet
2021 Mustang Mach-e GT (cyber orange)
2021 VW e-up! Range (hvit)
E-twow Booster 2S el sparkesykkel
ex 2011 Think City 4-seter (rød) Enerdel Lithium (ex Zebra), ESP, a/c og PTC varme
ex 2003 Kewet 5 (grønn)
ex Go Motorboard el sparkesykkel
Asker
Frederic
hello,
Where did you find your RLEC board ?
Thank you
Regards
runeno
I am sure elbilmek in Norway have RLEC cards available, but they are expensive. So, you should test first by switching the two RLECs on the same submodule. Then attach the batterypack to the car, and rerun the diagnose.
There might be private persons here that might have RLECs too. It is importantl that the new RLEC card uses the same slave ID AS the defect one.
Kind Regards
Rune
