Think City driveshaft
Startet av Maurice M, tor 15. nov 2018, kl. 18:50
Maurice M
Hi everyone, I have a Think City here in the Netherlands and I have a problem with the tripode joint and some other issues with my drive shaft. Can anyone tell me what parts Think used on the Think City .I would like to know the brand / make of the driveshafts of the "original " donor" car. Any and all help is very much appreciated. Greetings,
Maus
Maurice M
Hi Frederic,
Thank you for your reply. I will keep this in mind. Do you have any idea on what brand / make this drive shaft could be?
Kind regards,
arv
Del   Del(engelsk)   Info   Delenr.   Alternativt Delenr.   Donorbil   Pris
AC kompressor   AC compressor      AM64-19D623-AB      Ford Fusion   1300+/-
Startsperre-hjerne   Anti-theft brain(PATS)      XW7T-19A366-AA      Ford Mondeo/Focus
GEM-Hjerne   General Electronic Module(GEM)      17ST-15K600-KB   3S7T-15K600 MC   Ford Mondeo/Focus
Hovedlysbryter   Light switch      98AG-13A024-FG      Ford Focus
Bagasjeromsbryter   Trunk button      1006289      Ford Puma/Ka/Fiesta/Cougar
Ratt   Steeringwheel            Ford Focus MK1 alt. Mondeo MK3
Passasjerairbag   Passenger airbag            Ford Focus MK1
Rattairbag   Drivers airbag            Ford Focus MK1
Vindusviskerhendel   Windscreen wiper stalk   Seks innstillinger   1S7t-17a553-dd      Ford Focus/Mondeo/Fiesta
Blinklyshendel   Indicator stalk      98AG-13335-BG   1S7T-13335-BD/BE   Ford Focus/Mondeo/Fiesta
Rattdeksel   Steering column cover            Ford Focus MK1
Rattstamme   Steering column            Ford Focus MK1
Rattkontroll til radio   Steering wheel interface for radio      98AB 14K147      Ford Mondeo/Focus
Antennepisk + base   Radio antenna      97GP 18A886 AB , Ford (1087087)   XS8Z-18919-AA   Alt av Ford-modeller   NoK 158,-
Vindusheisbryter   Window switch      98AG-14529-CB      Ford Focus
Radio-deksel   Cover for DIN-opening      93BG13530BA      Ford Mondeo MK1
Vindusheis   Window regulator            Ford Focus MK1+MK2
Utv. dørhåndtak   Outside door handle      1S 71-22404      Ford Mondeo MK3, Farge: Stardust silver
Innv. døråpner   Door latch      Se kompl. dørlås      Mondeo MK3
Innv. dørhåndtak   Inside door handle       ?      Mondeo MK3
Deksel dørhåndtak   Cover door handle      2S71-F240K02-AAW      Mondeo MK3
Dørlås   Door latch      7096477      Ford Mondeo MK3
Speilbryter   Outisde mirror switch      93BG17B676       Ford – alle nyere modeller
Kompl. speil utvendig   Outside mirror      735481657      Fiat 500, Farge Mondeo Stardust silver
Bremselys   Rear high mounted stop light            Ford Focus MK1 Hatchback
Varmvannskolbe   Heater   Mes-Dea, varmeapparat   30X57224      E-carsupplies.com   €350-450
Baklys   Rear lights   Hella   4169 Series      Hella buss/lastebil
Bremsekraftforsterker   Brake servo   ATE   03.7752-9031.4
ABS-enhet   ABS   ATE   100207 01154   4S612M110DA   Ford Fiesta/Fusion/Ka
Hovedsylinder   Main brake cylinder   Usikker, ikke bekreftet   2617w j78   Nummer stemplet inn   ATE, uvisst.
Ekspansjonstank   Water header/expansion tank   Alfa Romeo   60504309      Alfa Romeo 33 m. fler
Kjølevannspumpe   Water pump   BOSCH   PA 66 – GF 30      BOSCH 058 PAD
Horn   Horn   Fiamm   0055306      Ford, Opel m.fler
Radiator   Radiator   Think   550.1020.D      Think. Finnes det en tilsvarende?
Lufteluke bak v. bakfanger   Coupé ventilation latch   Ford   97KG B280B63 AD      Ford Focus 2002
Soltak   Sunroof   Webasto   008552      Uvisst. Virker universal.
Understell/chassi
Fjærben f.   Strut/spring            Peugeot 106/Citroen Saxo
Bremseskive f.   Brake disc, front      64-553      Peugeot 106/Citroen Saxo
Bremsekloss f.   Brake pad, front      4254.83 (Micksg.: 36565)   www.micksgarage.com   Peugeot 106/Citroen Saxo   NoK 205,- 2 sett pluss frakt
Bremsecaliper f.   Brake caliper, front            Peugeot 106/Citroen Saxo
Hjullager f.   Wheel bearing front      74-0553      Peugeot 106/Citroen Saxo
Stabstag f.   Front anti-roll bar      72-353      Peugeot 106/Citroen Saxo
Bremseslange f.   Brake line, front            Peugeot 106/Citroen Saxo
Endeledd   Steering joint      72-983/72-984      Peugeot 106/Citroen Saxo
Bremsesko b.   Brake pads, rear(drum)            Peugeot 206
Bremsetrommel   Rear brake drum            Peugeot 206
Hjullager b.   Wheel bearing, rear            Peugeot 206
Kompl. bakaksel   Complete rear axle            Peugeot 206
Kjørt Think 2000 mod  133 000 km Byttet til Think 2008 Kjørte den 33 000 Km. Har nå Think 2011 m klima. Har nå kjørt min 2011 Think 60000 km siden 30 mars. Det nye stereoanlegget er helt topp!HarTMS85 som nå er byttet i en Tesla M3har nå bare to Elbiler.
Maurice M
Hello Inheritance.
Thank you very much for your list!
With kind regards,
Maurice M
Hi everyone,
The list provided by inheritance is very complete and correct for the most part, I think. I have been trying to find the correct driveshaft by searching for Peugeot / Citroen driveshafts. There is no driveshaft that comes close to the original one. Could they have used Italian parts (Fiat?) since the gearbox is Italian made. All input is very welcome.
