Ny spiker i bunkerskista?
Startet av Amatøren, tor 04. okt 2018, kl. 10:42
Trekkoppbil
Har man prøvd å seile NEDC-syklusen i laboratorium?
Sitat fra: Wikipedia link=https://en.wikipedia.org/wiki/New_European_Driving_Cycle
The Urban Driving Cycle ECE-15 (or just UDC) was introduced first in 1970 as part of ECE vehicle regulations; the recent version is defined by ECE R83, R84 and R101.[1][2][5] The cycle has been designed to represent typical driving conditions of busy European cities, and is characterized by low engine load, low exhaust gas temperature, and a maximum speed of 50 km/h.[6]
When the engine starts, the car pauses for 11 s - if equipped with a manual gearbox, 6 s in neutral (with clutch engaged) and 5 s in the 1st gear (with clutch disengaged) - then slowly accelerates to 15 km/h in 4 s, cruises at constant speed for 8 s, brakes to a full stop in 5 s (manual: last 3 s with clutch disengaged), then stops for 21 s (manual: 16 s in neutral, then 5 s in the 1st gear).
At 49 s, the car slowly accelerates to 32 km/h in 12 s (manual: 5 s in 1st gear, 2 s gear change, then 5 s in the 2nd gear), cruises for 24 s, slowly brakes to a full stop in 11 s (manual: last 3 s with clutch disengaged), then pauses for another 21 s (manual: 16 s in neutral, 5 s in the 1st gear).
At 117 s, the car slowly accelerates to 50 km/h in 26 s (manual: 5 s, 9 s and 8 s in the 1st, 2nd and 3rd gears, with additional 2 × 2 s for gear changes), cruises for 12 s, decelerates to 35 km/h in 8 s, cruises for another 13 s, brakes to a full stop in 12 s (manual: 2 s change to the 2nd gear, 7 s in the 2nd gear, last 3 s with clutch disengaged), then pauses for 7 s (manual: in neutral with clutch engaged).
The cycle ends on 195 s after a theoretical distance of 994.03 meters, then it repeats four consecutive times. Total duration is 780 s (13 minutes) over a theoretical distance of 3976.1 meters, with an average speed of 18.35 km/h.
NEDC-syklus til sjøs.....  :laugh:
Kanskje på tide å justere noe på tallene for Well to Wheel regnskapet på fossilt drivstoff...
