Zebra problem
Startet av Conny J, tir 07. aug 2018, kl. 10:13
Conny J
My Think is sad.. first i was working ok, but did not heat battery without ac power. Suddenly it stopped Powerlimit flashing. On ovms I read soc 100%, PackV 0 V PackC 0A Packtemp 245oC Chg temp 32 oC Amb temp 29oC aux batt 13,8 V.... disconnected 12V 30 min. Checked the same... how to continue?
Regards Conny
mohpet
My Zebra had power limit flashing, unfortunately that was internal isofault and no cure for the batteries. Could of course be something else. Good luck!
2021 Mustang Mach-e GT (cyber orange)
2021 VW e-up! Range (hvit)
E-twow Booster 2S el sparkesykkel
ex 2011 Think City 4-seter (rød) Enerdel Lithium (ex Zebra), ESP, a/c og PTC varme
ex 2003 Kewet 5 (grønn)
ex Go Motorboard el sparkesykkel
Asker
Conny J
Are there any freeware obd program that works on zebra to check error codes? On the ovms I se 1gen error, but no description. All the time the car was running it showed the same message to.
If no solution, next thing is to lower the battery and check more....
BauDemo
The nikometer (open source) will flash all error codes that are sent out on the can-bus, but that would probably not provide enough information about a specific problem with the zebra battery.
You need Zebra Monitor and P-CAN adapter + someone to guide and diagnose it.
BauDemo
Here is a version of the nikometer that Orla made that is meant for diagnostics:
http://www.tfv-org.dk/th!nk/diagnose/
Conny J
Thanks for the information! I look more on that!
