Lading på 22Kw
Startet av Pettrich, søn 11. feb 2018, kl. 10:26
Pettrich
Har noen vært borti at ZE40 ikke lader med 22Kw på 22Kw lader, selv ladeprosenten er nede på 40 ?
minibiti
If your battery pack is very cold then yes this can happen.
Oslo
2022 Megane Iconic (Aug 2024 - present)
2020 Zoe Intens R135 (Jan 2020 - Aug 2024)
Pettrich
minibiti
Then you should have gotten 22 kW in.
Where you sharing the charging point with someone else?
Do you know how much you got in exactly?
Oslo
Pettrich
Delte ikke med noen, men det tok omtrent dobbelt så lang tid som jeg hadde regnet med.
Snakket med en Renault selger som antydet at bilen kan være satt til å lade bare med 11 Kw ?
minibiti
The best is to get this checked at Motorforum under warranty.
Even better, if you can get hold of a OBD-2-adapter, you can check yourself with your phone.
This one uses bluetooth and is compatible with Android:
OBD-2-adapter ELM 327 for Bluetooth - OBD-2 Kjell.com
https://www.kjell.com/no/produkter/elektro-og-verktoy/verktoy/maleinstrumenter/obd-2/obd-2-adapter-elm-327-for-bluetooth-p48500
Oslo
Pettrich
Ok. Har ikke Android, men finne kanskje noe for Ios også ?
minibiti
Looks like for iPhone you have this:
https://www.kjell.com/no/produkter/elektro-og-verktoy/verktoy/maleinstrumenter/obd-2/obd-2-adapter-elm-327-for-iphone-p48400
It uses wifi instead of Bluetooth.
But I am a bit unsure which app you have to use then.
On Android, I use CanZE.
Maybe you search the forum for more info :)
With this, you should be able to see in real time how many kW the battery pack can take in, how many kW it does take in and how much is coming from the charger.
You would clearly see if the on board computer sees 22 kW from the charger but allows only 11 to the battery.
You can also see the temperature of the battery pack and much more.
A control question:
Have you ever managed to charge  with 22 kW from a 22 kW charger?
Oslo
pudderjagar
Korleis såg du at den ikkje lada med 22kw?
Er du sikker på at da var 22kw tilgjengeleg?
Kor mange % lada du?
Kva modell har du. 210/240/40?
Kjører:
Nissan e-nv200 Evalia (24kwh)
Pettrich
Regnet ut fra tiden at det ikke kunne være 22.
Laderen var 22 ja.
Husker ikke hvor mange %.
17 mod. Zoe 40
pudderjagar
Zoe 40 kjenner eg ikkje så godt men vil tru at ved 40% så vil du ha ein batteritemp på ca 12 grader hvis du starter ved -3. Då vil bilen strupe ladinga allerede ved 50%. Lader du då til 80% så vil du bruke ca dobbelt så lang tid.
Skal du ha håp om full effekt til 80% så må du ha ein batteritemp på over 20 grader og da får du ikkje på første lading. Men på andre gangs lading så vil du ha da utan problem.
Når du har så kalde batteri så lønner da seg å lade kun så mykje som du trenger for å kjøre til neste lader eller ca 1 time. Så har du full effekt og dermed vært turen totalt sett kortare enn om du presser den opp mot 90 til 100%
Kjører:
Pettrich
Takk for gode forslag.
Gjentar et spørsmål; Går det an å" stille inn" bilen til å bare ta i mot 11Kw ?
Speeder
Nei, det er ikke mulig å stille ladestyrken i Zoe.
Kjører:2021 Model 3 LR & 2021 E-208 GT - Tidligere: 2015 Zoe 22kWh/43kW
pudderjagar
Kan ikkje stillast frå bilen, bare hvis du har ein justerbar ladekladd eller justerbar ladestasjon
Kjører:
bjaolsen
Har vært borti at noen av søylene til Fortum har vært feil installert og gitt 16A og ikke 32A.
Dette løste seg (etterhvert) etter at jeg sendte inn informasjon til Fortum kundeservice.
bjaolsen
2020 e-2008
(2015 Zoe 43kW)
Jeg jobber i ABB, men er ikke direkte involvert med hurtigladere
