Porsche Mission E
Startet av Ferry, tirsdag 15. september 2015, klokken 07:15
Ferry
http://newsroom.porsche.com/en/products/iaa-2015-porsche-mission-e-mobility-all-electrically-concept-car-11391.html
"The key figures are: over 600hp, over 500km of driving range, 0-100km/h in under 3.5 seconds and a mind-blowing charging time of 15 minutes to reach a claimed 80 per cent charge. The power goes to all four wheels while there is also an all-wheel steering function."
"They also say that their new all-electric toy is capable of lapping the Nürburgring Nordschleife under the eight-minute mark."
flux
Ser bra ut!
Liker at de bruker 800V systemspenning, det reduserer problemer med ekstreme strømstyrker og varme i invertere/motorer. (Tesla)
http://www.porsche.com/microsite/mission-e/international.aspx
Lokführer
Himmel og hav så flott den bilen er!
Elbilist som unnlater å bruke kollektivfelt.
v-i-c
Sitat fra: flux på tirsdag 15. september 2015, klokken 11:51
Ser bra ut!
Vet noen mer om arbeidet til denne gruppen
http://www.iec.ch/dyn/www/f?p=103:14:0::::FSP_ORG_ID,FSP_LANG_ID:6619,25
Sitat fra https://webstore.iec.ch/webstore/webstore.nsf/xpPublication.xsp?Open&pubid=6584&test&SessionID=E7G4JF8PE3
Abstract
IEC 62196-3:2014 is applicable to vehicle couplers with pins and contact-tubes of standardized configuration, herein also referred to as "accessories", intended for use in electric vehicle conductive charging systems which incorporate control means, with rated operating voltage up to 1 500 V d.c. and rated current up to 250 A, and 1 000 V a.c. and rated current up to 250 A. This part of IEC 62196 applies to high power d.c. interfaces and combined a.c./d.c. interfaces of vehicle couplers specified in IEC 62196-1:2014, and intended for use in conductive charging systems for circuits specified in IEC 61851-1:2010, and IEC 61851-23:2014.
This publication is to be read in conjunction with IEC 62196-1:2011.
Det ser ut til at noen ønsker å øke overføringsevnen for energi til biler/tyngre kjøretøyer
Når ser vi noe resultat av dette.
Svart Zoe Intens 2015 (43 kw)
