Change of cabin filter
Startet av BauDemo, søn 15. feb 2015, kl. 13:00
BauDemo
I decided I wanted to change the cabin filter... and here are some photos and info:
http://www.evmonitor.info/2015/02/change-of-cabin-filter-on-think-city.html
Maybe someone proficient in Norwegian would like to update the wiki.
Nikolay
Frederic
Hello,
My Th!nk does not have a cabin filter (anymore?) ! where is it located ? on the fresh air intake in the motor compartment ?
can you provide a larger field picture ?
Thank you
BauDemo
It is inside the air intake.
The intake scoop is held in place by one screw to the right. You unscrew that screw and then remove the scoop by dragging carefully.
When you remove it you will see the filter.
I will try to take more detailed photos next time.
Or maybe you would like to do that and I can annotate them?
Frederic
Frederic
Frederic
Filter: Peugeot 206
PEUGEOT : 6447AZ - 6447TF (manual A/C or heating adjustment)
Suplier :
3F QUALITY : 1510 - 510
BOSCH : 1987431048
COOPERSFIAAM FILTERS : PC8060
CORTECO : 21651293
CTR : 1215299
DELPHI : TSP0325062
ECOCLIM : 1510
FILTRON : K 1066 - K1066 - QAP273
FRAM : CF9071
HENGST FILTER : E971LI
KNECHT : LA57
MAHLE FILTER : LA57
MANN-FILTER : CU3448
MECAFILTER : ELR7068
MICRONAIR : MP057
OPEN PARTS : CAF2052.01
PURFLUX : AH140
QUINTON HAZELL : QAP273
SogefiPro : PC8060
TECNOCAR : E341
VALEO : 698749
BauDemo
Nice!!
Thanks for the extensive list!
