Produkter
Startet av Thor2014, torsdag 11. september 2014, klokken 11:21
Thor2014
Hmm.
Det hadde vært fint å kunne redusere strømmen, men du har nok helt rett.
Jeg så det er en butikk som selger 750w motoren sammen et "flaskebatteri", så jeg sendte en Mail for å høre hva de mener om komboen.
Tror uansett jeg velger 48v, uavhengig om det blir den ene eller andre motoren.
Hvorfor velger du 36v fremfor 48v?
tahustvedt
Fordi da kan jeg bruke samme batteriene på alle syklene, pluss at jeg har masse DC-DC-regulatorer med maks spenning på 42 V. :)
Thor2014
Stuck med 36  ;)
Poster svar ang batteri og 750w motor.
Thor2014
Only the 20R version and the very soon to be released 25R version (10Ah) are well suited to the 750W BBS02 kit. 25R option will cost ~50USd more than the 11Ah 29E option:
Bafang 48V 750W BBS02 Kit with Battery
There are more options when the kit is programmed with lower power settings:
Bafang 48V 500W BBS02 Kit with Battery
There is some cost saving to order kit and battery together, we only offer suitable batteries as options.
We have an automated checkout on the site. If you select the items you are interested in, checkout as a guest (or register of course), then enter you address, you will be given a list of shipping options. Batteries should be shipped using an option with "Battery" in the description, non-battery parts you can select any option (but some options are not suitable for bulky/over-sized items). You can then checkout with Request a Quote if you are unsure about anything, want to use Wire Transfer or want to discuss an order. Checkout with PayPal if you are ready to Proceed. We can always modify an order if requested and will generally look over every order, and look for any possible errors. If just looking, no need to press "confirm" at the end of the checkout process.
Courier Shipment (DHL or Battery-Fedex) have a price break on 20kg plus shipments. The sub 20kg price per kg can be as much as double the 20kg plus price per kg. The first 0.5kg or 1kg of almost every shipping option are charged at a higher rate (does not apply to 20kg plus shipments, which are a fixed price per kg). It may or may not be cheaper to split an order into Battery and Non-Battery Parts. Battery shipments are more expensive than non-battery shipments. Typically if total weight with kit and battery is less than 12kg, it may be a little cheaper to split the shipment. If weight is closer to 20kg, it will generally be cheaper to combine and get the cheaper shipping cost for 20kg plus shipments. All scenarios can be checked using the online checkout. Note that some less popular destinations may not have all shipping options listed (but they may be available), so it would be best to checkout with request a quote.
