Tesla vs den tyske arven
Startet av Kjell Leaf, man 25. nov 2013, kl. 14:09
cyber
Audi har oppnådd gode rundetider på Nûrburgring med R8 e-tron ( teknologi lik TMS ) med en toppfart på rundt 300 km/h - er det en mekanisk girutveksling som gjør at R8 e-tron gjør det Model S ikke kan ?
Bjoris
Siden det er snakk om at det også skal gå ann å få dette som retrofit så virker det lite sannsynlig at det er en løsning med gir? Då må en vel i såfall bytte ut hele drivverket?
fonberg
Sitat fra: bjoris på man 02. des 2013, kl. 14:42
Har Tesla sagt helt konkret hva denne retrofit autobahn-tilpasningen består i? F.eks. om den vil gi høyere toppfart?
cairnz
Personlig tviler jeg på at det blir større toppfart.
Når det gjelder gir så var det to gir i de første proto- og testversjonene av Roadsteren, men dette gikk de bort fra.
Sitat
Starting in September, 2008 Tesla Motors selected BorgWarner to manufacture gearboxes and began equipping all Roadsters with a single speed, fixed gear gearbox (8.2752:1) with an electrically-actuated parking lock mechanism and a mechanical lubrication pump.[5]
The company previously worked with several companies, including XTrac and Magna International, to find the right automatic transmission, but a two-gear solution proved to be too challenging. This led to substantial delays in production. At the "Town Hall Meeting" with owners in December, 2007, Tesla announced plans to ship the initial 2008 Roadsters with their interim Magna transmissions locked into second gear limiting the performance of the car to less than what was originally stated (0-60mph in 5.7 seconds instead of the announced 4.0 seconds). Tesla also announced it would upgrade those transmissions under warranty when the final transmission became available.[3][27][46] At the "Town Hall Meeting" with owners on January 30, 2008, Tesla Motors described the planned transmission upgrade as a single-speed gearbox with a drive ratio of 8.27:1 combined with improved electronics and motor cooling that retain the acceleration from 0–60 mph in under 4 seconds and an improved motor limit of 14,000 rpm to retain the 125 mph (201 km/h) top speed.[47] The upgraded system also improved the maximum torque from 200 ft·lbf (270 N·m) to 280 ft·lbf (380 N·m) and improves the Roadster's quarter mile times.
Elbilist
Lokführer
Sitat fra: fonberg på man 02. des 2013, kl. 14:53
Min leveringsfyr i Tesla sa at autobahnpakka var å heve turtallsperra slik at bilen gikk 250km/t. I samme anledning nevnte han at den faktiske toppfarta på TMS er 330km/t!! Med påfølgende tomt batteri selvsagt, men wow!
Elbilist som unnlater å bruke kollektivfelt.
cairnz
Sitat fra: Lokführer på man 02. des 2013, kl. 15:33
Jeg skjønner ikke helt hvor de har den informasjonen fra - når denne informasjonen ikke kan finnes noen andre plasser. skulle tro slik informasjon skulle komme fra "toppnivå" hvis den er sann. Hvordan de kan få en Model S til å gå i 330 skjønner jeg ikke - i alle fall med dagens utveksling i girkassen. Se torque-kurve her: http://www.teslamotorsclub.com/showthread.php/17256-The-real-top-speed-of-the-Model-S/page4
Elbilist
Bjoris
Det må jo bare bety at de har en testbil med flere gir:) 330 km/t, blåser bra fra takluka da tenker jeg:)
Lokführer
Jeg er helt enig, ut i fra grafen er jo dette umulig. Kanskje det er et regnestykke hvor kun hk, rullemotstand, vekt og luftmotstand er tatt med. Med optimal utveksling?
kimnaess
Dette er jo det interessante (klippet fra US Forumet):
"The point you make is certainly valid albeit you may be in for a pleasant surprise. Two German journalists already tried to bring down range as far as possible by racing the Autobahn, and they could still go 250 km (155 mi) on a single charge. That counts as "meaningful" in my book."
http://www.manager-magazin.de/lifestyle/auto/a-897203.html
Ellers er jeg veldig enig i at selv om Tesla ikke går i 250, mangler sportseter, ACC pluss en del andre gadgets, så har likevel bilen en "må ha" faktor som bare Apple har hatt tidligere, det vil garantert bli solgt en del tusen biler i Tyskland bare på grunnlag av at det bor 80 millioner mennesker der.
Med 750 millioner mennesker i Europa, 350 millioner i USA og Canada, 1,3 milliarder i Kina så tror jeg nok lett at vi får se at Tesla lykkes med å selge 240 000 Model S til 2,4 milliarder mennesker på 2-3 år. Det er bare 0,01% av folkeantallet i disse verdensdelene...
Masse morsomme fossilbiler
Tesla Roadster 2012
Tesla Model S P85+ 2013
Tesla Model S P85D 2015
Tesla Model S 70D 2015
Tesla Model X 60D 2016
Tesla Model S 60D 2016
Tesla Model X 90D 2017
Tesla Model X 100D 2018
Tesla Model 3 LR 2019
Sitat fra: bjoris på man 02. des 2013, kl. 16:35
Det trengs ikke flere gir, kun høyere utveksling på det ene. Det vil gå ut over 0-100 tiden, mens f.eks 100-200 sannsynligvis vil bli vesentlig bedre.
elpedros
[quote author=kimnaess link=topic=10737.msg150659#msg150659 Med 750 millioner mennesker i Europa, 350 millioner i USA og Canada, 1,3 milliarder i Kina så tror jeg nok lett at vi får se at Tesla lykkes med å selge 240 000 Model S til 2,4 milliarder mennesker på 2-3 år. Det er bare 0,01% av folkeantallet i disse verdensdelene...
[/quote]
Men klarer de å produsere/levere så mange biler på 2-3 år, det er vel det store spørsmålet..
Nå er det vel også trolig slik at denne type sportssedan/coupe appellerer til et relativt smalt segment, både pga pris, utforming, løsninger og størrelse. Det er bare her i nisseland en slik bil kan konkurerre på salgstoppen mot biler som Golf, Auris etc og det tror jeg er høyst midlertidig. Selv om det er "verdens beste bil" for mange her inne, er det ikke en bil for massene.
En "high tech" bil designet og produsert i Cali, blir neppe heller stående i historiebøkene som den beste vinterbilen gjennom tidene.
For de av oss som sverger til tysk ordnung, er det beste med denne bilen at den muligens vil fremprovosere produksjonen av noen bedre alternativer fra bayern, stuttgart eller ingolstadt.
kimnaess
#326
Sitat
Kremt kremt kremt, imponerende av disse tyskerene med "ordnung muss sein" ja...
http://www.dinside.no/925276/bmw-i3-i-leveringskrise
Tesla Roadster 2012
i_expect
Fra dinside.no saken om i3: Kundene har ikke blitt fulgt opp med informasjon om når bilen kommer, og forhandlerne har ikke visst når kundene kan bestemme seg for farge og utstyr.
Høres det kjent ut? Ikke bare Tesla som sliter med kommunikasjonen til ivrige kunder med andre ord?  ??? Jeg trodde det bare var Tesla som slet med sånt og at de gamle gode bilprodusentene virkelig kunne dette med informasjon og levering. Skjønner ingenting nå jeg. Nå ble jeg virkelig skuffa. Huff, skal aldri kjøpe tysk igjen. Får jo ingen info! Jaja.  ;)
Tesla model X (kjøpt 2016) og Leaf (kjøpt 2011) i familien. Ingen med forbrenningsmotor lenger... bortsett fra i traktoren og  i sjekta!
Bjoris
Sitat fra: i_expect på tir 03. des 2013, kl. 10:50
Ja, en skal vokte seg vel for skadefryd, men det er en bra ripe i lakken for den tyske arven dette, spør du meg. På toppen av en kollisjonstest som ikke var bra nok...
OddB
Dette viser at BMW tydeligvis ikke hadde sett for seg noen masseproduksjon av denne bilen.
Hvis Norge er det største markedet og de ikke klarer å levere mer enn 1500 biler i året kan ikke den produksjonslinjen være stor. Det er mulig at de har større problemer med å skaffe batterier enn Elon ?
Burde kanskje ikke drevet så aktiv markedsføring før ting var på stell...
