NissanConnect EV-app avvikles fra 30. mars 2026
Startet av m55ikael, tir 24. feb 2026, kl. 12:18
sjokomelk
Det står dessverre tydelig i T&C for NissanConnect at Nissan står fritt til å kansellere tjenesten når som helst og når de måtte finne det godt. Men de skal varsle minst 30 dager før de kansellerer. Og det har de gjort nå.
Så man har ingenting juridisk å gå på som kunde. Man har godkjent dette når man tok i bruk tjenesten.
https://gb.nissanconnect.eu/en-gb/CsmTerms
Sitat2.3. Our Termination and Suspension Rights.
We may terminate your NissanConnect Services at any time and without cause, in which case we will give you notice 30 days prior to the effective date of termination after which your NissanConnect Services will end. This means that we can decide to cease providing the NissanConnect Services to you at any time and for any reason, even for reasons unrelated to you or your account with us. In case we decide to terminate the NissanConnect Services in the event of termination of any agreement between us and any Service Provider on which we are dependent to provide the NissanConnect Services, we will use our best endeavours to give you the 30-day notice mentioned above.
Also, we may terminate your NissanConnect Services without prior notice to you for any good cause. This means, for example, we can terminate your NissanConnect Services immediately if you breach any part of this Agreement, if you interfere with our efforts to provide the NissanConnect Services, if you interfere with our business, or if your NissanConnect Services is used for illegal or improper purposes. You do not have any right to have NissanConnect Services reactivated, even if you cure any of these problems. We can also suspend your NissanConnect Services for network or system maintenance or improvement, or if there is network congestion, or if we suspect your NissanConnect Services are being used for any purpose that would allow us to terminate it. In such events, we will not reimburse any amounts you have paid in advance for the NissanConnect Services.
We also reserve the right, at our sole discretion, to stop offering the NissanConnect Services and not to accept the renewal of your NissanConnect Services without incurring any liability whatsoever.
Ratter 2026 Tesla Model Y Performance
Sitat fra: sjokomelk på tor 19. mar 2026, kl. 11:59Det står dessverre tydelig i T&C for NissanConnect at Nissan står fritt til å kansellere tjenesten når som helst og når de måtte finne det godt. Men de skal varsle minst 30 dager før de kansellerer. Og det har de gjort nå.
Det er jo også et spørsmål om hvordan bilen ble markedsført. Hvis man ble informert om at bilen har app-funksjonalitet før man kjøpte bilen kan man ikke etter kjøpet bli forelagt en avtale om at bilen ikke nødvendigvis har det.
2021 Tesla Model Y LR
2016 Kia Soul
sjokomelk
Sitat fra: Rosstopher på tor 19. mar 2026, kl. 12:19Det er jo også et spørsmål om hvordan bilen ble markedsført. Hvis man ble informert om at bilen har app-funksjonalitet før man kjøpte bilen kan man ikke etter kjøpet bli forelagt en avtale om at bilen ikke nødvendigvis har det.
Appen er ikke solgt med bilen. Bilen er solgt med mulighet for appfunksjon levert av NissanConnect som igjen har sine egne T&C. Nissan har i all tekst kun skrevet at muligheten finnes, og med liten skrift på samme side henvist til NissanConnect.
antohagg
Her har Nissan underkommunisert hva som faktisk blir borte. De har ju rett å slett fjernet hele nett-tilkoblingen i bilen.
Spurte hvorfor jeg ikke lenger kan oppdatere ladestasjoner i bilen og filk dette som svar. Dette går ju mye lenger enn å bare legge ned en app.  :-1:
Takk for at du tok kontakt med oss i Nissan Kundeservice.
Dessverre, så er også funksjoner som var avhengige av mobilnettverket – som kartoppdateringer, trafikkinformasjon i sanntid og mer – påvirket av nedleggelsen, og vil ikke lenger være tilgjengelige.
GPS og lokalt lagrede kart vil fungere, men vil ikke bli oppdatert. Tilkoblede funksjoner som sanntids trafikk, ladestasjoner og søk etter POI på nett er stoppet. Funksjonen å se sanntids informasjon om ladestasjoner er ikke lenger tilgjengelig i bilen.
Vi anbefaler å bruke Nissan Charge-appen for stasjonsplasseringer, tilgjengelighet og veibeskrivelser. Denne kan du laste ned gratis i app-store.
Ikke nøl dersom du har andre spørsmål.
Ønsker deg en fin dag.
Med vennlig hilsen,
