Model 3 - OTA økte batterivarmer fra 2.5 til 6 kW
Startet av olavxxx, fredag 29. mars 2019, klokken 14:33
olavxxx
Ps: batterivarmer i Model 3 utføres ved å kjøre bakre motor "ineffektivt", det er ikke en resistiv varmer.
Sitat:
Prior to 2019.8.3, the measured amount of power this heater used (total wall power minus battery charging rate) was ~2.5 kW. This value is programmable, and per this teardown video it appears to have been coded at 2.56 kW as of last year (for the LR RWD at least). My own API measurements up to 2019.5.15 matched this amount. Here's my Model 3 AWD on 2019.5.15 charging from 80% to 90% at 2.5°C three days ago: https://imgur.com/Rcpjg7d
On 2019.8.3, my measurements suggest the battery heater now draws as much as 6 kW. Here's my Model 3 AWD on 2019.8.3 charging from 80% to 90% at 1.5°C today (I included inside temperature to show that the cabin heater wasn't running): https://imgur.com/h1FCXNM
Kilde:
https://www.google.com/amp/s/amp.reddit.com/r/teslamotors/comments/b677nd/fw_201983_appears_to_increase_model_3s_battery/
gruffalo
E-tron 55 sportback 2022
olavxxx
Når du varmer kupe og det er kaldt, eller hvis du legger inn superlader som destinasjon i navi.
Sitat fra: olavxxx på fredag 29. mars 2019, klokken 15:31
Noen som har funnet info om batterivarmen kan slås på når bilen ikke er tilkoblet strøm?
