Hvor ofte ta service?
Startet av tuslaman, tirsdag 07. august 2018, klokken 09:11
Jeronan
#15
Now you mention it, they also don't specify the prices at all anymore!
Used the be around 5800 NOK for the 20k KM service and around 7300 NOK for the 40k KM service if I remember correctly. Was also slight price difference between rear wheel drive and AWD drive, probably because like you said that it included DU fluid change, which is now removed. Probably no longer necessary on the latest DU's?
Bit annoying they no longer mention prices, but it should be cheaper now, since DU fluid change is removed.
Model Y - Sept 2021
Model S 75D - Sold
BMW i3 2017 - Feb 2017
Spinner
Sitat fra: Jeronan på tirsdag 07. august 2018, klokken 14:36around 7300 NOK for the 40k KM service if I remember correctly.
Jeg betalte 7600,- for 40k service på en 2015 90D for 1 mnd siden.
fonberg
Sitat fra: Sbr på tirsdag 07. august 2018, klokken 16:10
Antar 7600,- da var inkl. bremseservice?
Her er info jeg fikk fra Tesla ifm. avtale om 20k service (beklager at jeg ikke retter opp særskrivinga):
-20.000 Service ( Kunde kostnad kr 5800,- )
-Bremse service ( dette er kun om du ønsker å få det utført, da vil det komme en tilleggs kostnad på kr 1812.50,- )
18 i3 FC | 2017 S90D | 19 Ioniq | 00 Porsche 911 --- Model Y bestilt 31.3.2019, taes ut juni 22.
