Geely E5/EX5/Galaxy E5 460 kW 70 kWt batteri, vekter & tall
Startet av elekTrond, ons 30. sep 2026, kl. 03:02
elekTrond
Adekvat, helt grei, 4,6 m lang, passe lett, fem dørs budsjettbil med
  • 460 kW DC fra et 800 V 70.01 kWh, kalt
  • mk2 Aegis Ultra Short Blade LFP
  • aka Shendun Golden battery
  • 497 kg 7,1 kg/kWt
  • 1740 kg bil / 70 kWt = 24,9 kg bil per kWt
Åffer ser vi ikke den i Norge?
Leselyst:
SitatGeely EX5, or the Geely Galaxy E5 (Chinese: 吉利银河E5; pinyin: Jílì Yínhé E5) in China,
Geely E5 (South Africa and Europe)
  • EU launch june 2025. For Europe, it is available with 49.5 kWh and 60.2 kWh battery packs.
  • Platform Global Intelligent New Energy Architecture (GEA)
  • Battery
  • FWD 400 V Aegis Short Blade LFP
  • 49.52 kWh 386 kg 7,8 kg/kWt 2024–25
  • 60.22 kWh 443 kg 7,4 kg/kWt 2024– 120 kW DC
  • 68.39 kWh 483 kg 7,1 kg/kWt 2025–26
  • RWD 800 V mk2 Aegis Ultra Short Blade LFP
  • aka Shendun Golden battery 460 kW DC
  • 61.52 kWh 443 kg 7,2 kg/kWt 2026-
  • 70.01 kWh 497 kg 7,1 kg/kWt MY27
  • Plug-in charging
  • 7 kW single-phase (AC)
  • 11 kW three-phase (AC, export)
  • 110/120/460 kW (DC)
  • Length 4,615 mm
  • Kerb weight 1,615–1,740 kg
Sitat
  • The vehicle's software adopts the Flyme Auto operating system and Flyme Sound audio system, developed in conjunction with the company-owned Meizu. The system is powered by the Dragon Eagle-1 system on a chip (SoC), an automotive SoC produced with a 7 nm process.[17]
  • Higher variants are available with variable dampers and a 23-speaker sound system. It is now available with a G-ASD H5 Level 2 ADAS system, which has a sensor suite consisting of one LiDAR, 3 mmWave radars, 11 cameras, and 12 ultrasonic sensors and is powered by a Horizon Robotics Journey 6M chip.[20][21]
  • The EX5 is offered with a single-motor, front-wheel drive setup, paired with Geely's self-developed lithium iron phosphate (LFP) battery called the Aegis Short Blade.[22]
  • integrated with a 11-in-1 intelligent electric drive system, which unifies 11 major devices such as motors, electronic controls and reducers.[17] Its battery is integrated to the body with cell-to-body (CTB) integration.
  • facelifted 2027 model is equipped with a rear-motor, rear-wheel-drive layout with a more powerful 245 kW (329 hp; 333 PS) motor in a Leishen 16-in-1 drive system.
  • two new battery packs with 800-volt power electronics using Geely's second generation Aegis Ultra (also known as Shendun Golden battery) short blade battery cells, which are capable of recharging from 10–70% in 8 minutes and 25 seconds.[20]
c",)
'13 Mjau
