Skrevet av Emne: BYD Tang med refreshed design og større batteri  (Lest 1549 ganger)
Blitz
« på: Onsdag 10. November 2021, klokken 20:13 »
The most prominent design change is in the front of the vehicle which now comes with a more modern-looking, minimal grille . This year’s model featured a grille that occupied a larger part of the front of the EV but the newer design comes with a smaller one with chrome trim. The newer grille also holds the “Tang” car logo.
Apart from this, the rest of the body hasn’t been changed much. The rear and sides of the vehicle are almost indistinguishable from its older model, although the body length has been increased slightly. As such, the length, width, and height of the new BYD Tang EV are 4900mm x 1950mm x 1725mm, respectively, while the wheelbase stands at 2820mm.
Moving on to the SUV’s engine, it is an electric motor with a power of 168kW (approximately 229 horsepower). The power has in fact been reduced when compared to the current single-motor version of the Tang EV. However, a dual-motor four-wheel-drive version is expected to be launched soon to compensate.
The lithium iron phosphate Blade Battery of the new BYD Tang EV has been upgraded with an increased density, rising from 140wh/kg to 150wh/kg, which is a considerable upgrade. Because of this, the battery life/range of the vehicle will be reaching 700 kilometers.
Current BYD Tang EV models on sale are three in number, namely long-range, four-wheel-drive high-performance, and four-wheel-drive high-performance flagship.
The newer model will be replacing the current single-motor variant and is set to be unveiled at the Guangzhou Auto Show on November 19.
https://www.gizmochina.com/2021/11/10/byd-tang-ev-announced-with-a-new-design-and-700km-battery-range/
Dagens Tang med firehjulsdrift har vel en NEDC rekkevidde på 500 km, så med det nye batteriet bør vel rekkevidden øke til 600-650 km NEDC og 500 km WLTP.
« Siste redigering: Onsdag 10. November 2021, klokken 20:24 av Blitz »
JorgenM
    • LinkedIn
Sv: BYD Tang med refreshed design og større batteri
« Svar #1 på: Torsdag 11. November 2021, klokken 04:38 »
Trist at de fjerner grillen fra dagens versjon. Den nye ser desverre langt mer Kina ut. Jeg har avventet kjøp pga ryktene om oppgradert rekkevidde, men ble litt skuffet nå. Vi får se 19. november da.
i-Pace levert 04.07.2019 - 2013 Tesla S P85 (solgt) - Nitrox EL go-cart - 2x BMW i3 (1 solgt)
Vaduz
« Svar #2 på: Torsdag 11. November 2021, klokken 16:57 »
Likte den nye grillen mye bedre, digre griller er veldig gammeldags på en elbil synes jeg. Med såpass rekkevidde kan den faktisk bli aktuell etterhvert, særlig om man kan fjerne drømmebygger bokstavene bakpå!
« Svar #3 på: Torsdag 11. November 2021, klokken 20:41 »
Den teksten er litt som å ha Home Sweet Home på veggen hjemme  ::)
« Svar #4 på: Mandag 06. Desember 2021, klokken 20:29 »
Var det noen som sa "Voldemort"?
Mine videoer av autopilot 2 på YouTube
2021 ID.4
2021 Model 3 LR
2019 Audi e-tron
2019 I-Pace
2017 S90D
Kjell Leaf
  • Leaf Tekna des.2013
« Svar #5 på: Tirsdag 07. Desember 2021, klokken 14:06 »
Rekkevidden blir langt fra det som noen antyder her. 700 km nedc tilsvarer sannsynligvis i underkant av 600 wltp. I tillegg er det single motor som omtales ger, og forskjellen mellom 2wd og 4wd bruker å være ganske stor. Jeg tipper rundt 500 km på 4wd.
Leaf Tekna, levert des. 2013.
Farge : Hvit
J0kerN
  • Newbie
« Svar #6 på: Torsdag 09. Desember 2021, klokken 11:28 »
«The newer model will be replacing the current single-motor variant and is set to be unveiled at the Guangzhou Auto Show on November 19.»
Dette skjedde vel ikke?
Blitz
« Svar #7 på: Torsdag 13. Januar 2022, klokken 17:23 »
Bilde av den "nye" Tang, synes fronten ser bedre ut uten grill.
