Skrevet av Emne: Speaker cover  (Lest 198 ganger)
BauDemo
    • www.uppladdning.nu
Speaker cover
« på: Mandag 12. April 2021, klokken 10:35 »
My speaker covers are falling all the time and are beginning to crack.
So I made a 3d model of a speaker cover and 3d print it.
Here are some photos of it. I will upload the model if there is any interest in it.
https://photos.app.goo.gl/ynoc7SLRZbACo5Xp6
Warlock
Sv: Speaker cover
« Svar #1 på: Mandag 12. April 2021, klokken 18:17 »
Nice print
You could of course also just order grills for a Ford (galaxy) speaker, 155mm
(bought new for mine a few years back from ebay, be ware not to pick the dark blue ones)
BauDemo
Sv: Speaker cover
« Svar #2 på: Mandag 12. April 2021, klokken 21:11 »
Thanks for the tip!
That explains some of the strangeness... it is visible on my photos that the original cover has one of the pins that are supposed to fit in the door a little off, while if you look at the door opening all 8 or the openings are symmetric.
I am very happy with the new covers, but it is definitely more cost effective to order new from ebay.
Warlock
Sv: Speaker cover
« Svar #3 på: Tirsdag 13. April 2021, klokken 13:30 »
Yeah, they look great!
Are you planning sharing the stl-files (or .gx) in some way? On thingiverse for instance?
BauDemo
Sv: Speaker cover
« Svar #4 på: Tirsdag 13. April 2021, klokken 15:13 »
There you go:
https://www.thingiverse.com/thing:4826715
I made it with FreeCAD, let me know if you want to original model file.
« Siste redigering: Tirsdag 13. April 2021, klokken 15:18 av BauDemo »
Warlock
Sv: Speaker cover
« Svar #5 på: Onsdag 14. April 2021, klokken 16:50 »
Perfect  :+1:
I dont need new ones right away, and I'm more than convinced your version will be perfect if/when i need it. Have already collected them at Thingiverse. Don't think I need the CAD-files, but if I ever do, I'll hunt you down ;)
