Skrevet av Emne: Zebra battery, red triangle, power limit blinking, you know - the usual stuff  (Lest 1336 ganger)
Damir
« på: Lørdag 30. Januar 2021, klokken 17:39 »
Hello,
I have just bought a Th!nk City 2010 car with a Zebra battery.
The previous owner stated that the car won't take charge.
The car hasn't been charged for, at least, a year.
First thing I tried is to charge the 12V battery for a couple of days. Everything worked as supposed to (lights, horn, mirrors, radio, wipers etc.), however the "power limit" was blinking and the red triangle was lit all the time. When I plugged in the original charger, the external power supply indicator on top of the dashboard (the right one) lit up and the left one was blinking. The "car link" diod on the charger was blinking. The red triangle on the dashboard remained lit. No other warning lamp is lit.
I have bought a brand new Varta B18 12V battery and replaced it. The symptoms remained the same as with the old battery. I have connected a multimeter to a 12V socket and it shows 12.0V. When I turn the lights on and the fan to the maximum (nothing else), it shows 11.6V. When I connect the car to a charger, it says 12.5V. When I turn the ignition key, the charge level gauge slowly raise to 35%.
I have no PCAN device, so at the moment I am not able to provide with more information.
Can you recommend a cheap one I could get, perhaps somewhere online?
Or I could borrow one from the local mechanics.
I am located in Serbia, unfortunately we don't have EV mechanics yet anywhere around.
Any of your help will be much appreciated.
Damir
worry
Sv: Zebra battery, red triangle, power limit blinking, you know - the usual stuff
« Svar #1 på: Tirsdag 02. Februar 2021, klokken 08:29 »
Hi,
Sorry, but this forum have been rather quiet lately. I'm not able to help, but did you try the FB forum The Think-Tank?
Think lithium
VWspirit
« Svar #2 på: Tirsdag 02. Februar 2021, klokken 18:56 »
You’r zebra battery is death.... only fix is replasement battery.
Build a new one from a leaf-battery
Bosted:Steine, Vestvågøy...*Heggedal, Asker
Jaguar I-Pace 2019
Tesla S100D Pearl White 2019
Think 2011 Sort 2+2 Li (bygd om fra zebra)
*Think 2009 Sort, Li (bygd om fra zebra)
*Think 2002 Sort, 3x25A 230V hurtiglader
*Citroen Saxo 2002 Blå met.
*VW Golf Citystromer 1998 56600km
Damir
« Svar #3 på: Torsdag 04. Februar 2021, klokken 21:21 »
Hi,
Yeah, I'm a following that page.
Guess I'll find some answers there, thanks.
That's what I was afraid of.
Damir
« Svar #4 på: Torsdag 04. Februar 2021, klokken 22:28 »
What would I need in order to make the Th!nk work with the Leaf battery?
Same question if I stumble upon a Li-Ion battery.
VWspirit
« Svar #5 på: ſøndag 07. Februar 2021, klokken 20:57 »
Depends on the pcu. If it’s gen 2 then it’s almost plug and play. You only need to change the high voltage cabe.
Jaguar I-Pace 2019
Damir
« Svar #6 på: Fredag 12. Februar 2021, klokken 08:14 »
How to find out?
The car is 2010.
pexic
« Svar #7 på: Fredag 12. Februar 2021, klokken 08:19 »
You can use CHAS software to find out, read here on this forum (using google translate) how to connect a laptop to the "serial" plug located under the fuses. good luck!
Damir
« Svar #8 på: Torsdag 18. Februar 2021, klokken 09:37 »
Here is the diagnostic result:
Also, it is attached to this post.
So, what would be the best possible solution to go with next?
Damir
« Svar #9 på: Lørdag 20. Februar 2021, klokken 14:35 »
Can you tell if this is a GEN2 version?
Would it be easy to swap it to Li-Ion battery?
worry
« Svar #10 på: ſøndag 21. Februar 2021, klokken 22:39 »
This diagnose does not tell anything. It seems to be a CAN fault, but might also be due to a non compatible test equipment.
To see if your City is GEN2 check here: http://elbilwiki.no/index.php/Ny-Think
GEN2 starts from VIN 5373
Think lithium
Damir
« Svar #11 på: Mandag 22. Februar 2021, klokken 22:58 »
Seems like mine is GEN1 - VIN is U005019
Damir
« Svar #12 på: Lørdag 31. Juli 2021, klokken 20:16 »
UPDATE after 4 months:
Well, I have managed to get the PCAN adapter, installed Oracle VM on my laptop and ZebraMonitor on it. The Internal ISO and AC heater faults have been listed, which I deleted. The car started heating up the battery and eventually started charging up. I was happy like a small child. Have been driven it since then for 4.000 km with no problems.
Just the other day, all of a sudden, the car wouldn't run: red triangle lit, power limit blinking, don't won't to take a charge. Since I have borrowed the PCAN adapter the first time, I have had to get me another one. It took me two weeks to finally get it. Now ZebraMonitor shows the same faults like last time. I have deleted them again and the car started heating up the battery, hopefully will take the charge once it reaches the temperature. BMI SW is 3.12.12.
What is AC heater?
What is DC heater?
How could I sort out this problem once and forever?
Many thanks
EDIT: I have always paid attention to start charging when the battery was around 10% and then charging it all the way up to 100% (every 3rd day). I was getting 180 km of range on full charge, but most of the time I was getting around 140 km in a 3-day period.
« Siste redigering: Lørdag 31. Juli 2021, klokken 20:22 av Damir »
BauDemo
    • www.uppladdning.nu
« Svar #13 på: Mandag 02. August 2021, klokken 21:03 »
I would not wait for the battery to get to 10% to start charging, and would start the charging much above that - say 30%.
Damir
« Svar #14 på: Onsdag 04. August 2021, klokken 23:29 »
This is exactly what I was thinking about.
Also, charging it over 80% only when really needed, would might be a good idea as well.
