Hjelp til kjøp av brukt Zoe
Startet av Bgk, ons 13. jan 2021, kl. 19:26
Bgk
Hei, lurer på å kjøpe en brukt zoe, men kan veldig lite om disse bilene så spør om litt hjelp her😊 noen som kan si om dette er et bra kjøp?? https://www.finn.no/car/used/ad.html?finnkode=204179892
minibiti
I would say ok-ish...
But it is a Life not an intens so you are missing some options (back-up camera, parking sensors, electric windows in the back,...).
You are also not getting the "ladebøtte" which allows you to charge from a normal socket (10A Schuko) at the wall. It very often comes with the car and costs around 10KNOK new.
This means that if you want to charge at home, you will have to buy one yourself, or have a Type 2 charger which delivers TN current, which is not common here around Oslo (unless you have a brand new house and 400V). You have several alternatives to install such a charger/transformer of you have IT at home.
On the plus side, low mileage. But the car is 2 years old so it would be interesting the SoH of the battery.
Oslo
2022 Megane Iconic (Aug 2024 - present)
2020 Zoe Intens R135 (Jan 2020 - Aug 2024)
minibiti
One thing I forgot to mention is that the car has a 92 HP engine, not the newer 100 HP one which is common for the models from late 2018.
Oslo
Bgk
Med denne som referanse, kan du sjekke Finn.no for private salg. Gjerne ikke like glinsende i lakken, men det er da heller ikke denne dagen etter du kjører den ut av butikken. ;)
https://www.finn.no/car/used/search.html?location=22030&location=20061&model=1.804.2000301&price_from=5000&price_to=180000&sort=PRICE_ASC
