Skrevet av Emne: Th!nk CoC (Certificate of Conformity)  (Lest 235 ganger)
Damir
  • Newbie
« på: Onsdag 18. November 2020, klokken 14:57 »
Hello,
I would like to import a Th!nk City (2010) car to Serbia from Austria.
The customs are looking for a CoC (Certificate of Conformity) document.
Is there a way to download it or get it from the manufacturer?
Maybe some user of this forum could supply me with it?
Thank you,
Damir
Google translate:
Hallo,
Jeg vil gjerne importere en Th! Nk City (2010) bil til Serbia fra Østerrike.
Tollvesenet leter etter et CoC-dokument (Certificate of Conformity).
Er det en måte å laste den ned eller få fra produsenten?
Kanskje noen brukere av dette forumet kunne forsyne meg med det?
Takk skal du ha,
Damir
pexic
Sv: Th!nk CoC (Certificate of Conformity)
« Svar #1 på: Onsdag 18. November 2020, klokken 19:10 »
Hi, in my case (two imported Think City -2010 and 2014-  from Austria to Romania) the autorities have checked some info from the motor (they also called this info as "CoC").
I was curios and they show me some label  writted on motor abd this had " CE " letters, they said: that's it. Don't know in your case since you are not in EU yet..
I hope this helps.
Good luck.
Damir
  • Newbie
« Svar #2 på: Fredag 27. November 2020, klokken 12:32 »
Thank you very much for your help.
I already have the COC document, however it is issued by an Austrian company. The customs are asking for the official certificate issued by a manufacturer in Norway.
The CE letters that you are referring to (UN ECE R101) seems to be an EU-approved carbon dioxide emission rating.
I'm still not sure how to obtain this document from a factory that has stopped working for almost a decade.
EDIT: The document I have is for my vehicle and contains all the data, including the VIN number, however it is extracted from a database and not the official one.
« Siste redigering: Fredag 27. November 2020, klokken 14:54 av Damir »
Warlock
« Svar #3 på: Fredag 27. November 2020, klokken 16:41 »
Damir
  • Newbie
« Svar #4 på: Fredag 27. November 2020, klokken 17:19 »
Something like this?:
https://www.dropbox.com/s/dj50sjinhyudc99/COC%202010%20Think.pdf?dl=0
I don't want to celebrate yet, but I am very grateful for the help from both of you!  :) :)
I will send this for clarification.
Small corrections on the document will be needed, though.
