Nyhetsbrev
E-post *
Skrevet av Emne: Ladekabel uten kladden  (Lest 86171 ganger)
Ladefabrikken
  • Hero Member
    • Vis profil
    • Ladefabrikken
« på: Fredag 27. April 2012, klokken 16:43 »
Jeg fant denne på svensk elbilforum, nettsiden hans funker ikke enda.
http://www.elbil.forum24.se/elbil-about3534-0-asc-0.html
Version 1 of my new J1772 10/16A very mobile charger is ready and tested on my Nissan Leaf yesterday.
Worked as a charm. 16A charging is noticeably faster then 10A.
The charger is without the standard heavy box on the cable and has a button on the J1772 handle for selection between 10A and 16A. The button also has a led for indikation of status and charging speed.
The other end has a regular european plug (Schuko) rated for 16A.
If there are demand I will take v2 into produktion and sell these. So let me know if you are interested.
EDIT: It seems that there a quite a demand for this type of charging cable so I have started the production of v2. I'll let you know when it is available for the public.
/Fredrik
____
When taken into production, I will sell the charger at www.chargeamps.com
1 Stk sort Leaf
1 1/2Stk Clio electric
Reservert Model 3 31.03.16
http://www.ladefabrikken.no
Salg av ladekabler
Smiling when sailing
  • Full Member
    • Vis profil
Sv: Ladekabel uten kladden
« Svar #1 på: Fredag 27. April 2012, klokken 17:10 »
Ser jo kult ut, men da mister man all den sikkerheten som kladden skal være god for. Men det lover i hvert fall billigere kabler for framtiden. Det gjelder vel bare å vente og se.
Blå Leaf, Tromsø
erikf
  • Hero Member
    • Vis profil
« Svar #2 på: Fredag 27. April 2012, klokken 17:13 »
Ser skikkelig digg ut. Skal visstnok få knapp der man velger mellom 6, 10 og 16 ampere i følge det svenske forumet.
Er den store kladden egentlig unødvendig? Hvilken sikkerhet har den som ikke svensken har bygget inn i sin løsning?
Bergen - Leaf 2012-2019 - model3 2019-
koffeld
  • Full Member
    • Vis profil
« Svar #3 på: Fredag 27. April 2012, klokken 23:10 »
Det ser nesten for godt ut til å være sant...  At det nok er god plass innenfor plasten i dagens kladd er jeg ikke i tvil om, men at det allerede skal være mulig å dytte alt av relevant elektronikk inn i en av støpslene synes jeg virker drøyt.  At vi nok kommer dit om noen år tror jeg gjerne, men at utviklingen har gått så fort, stiller jeg meg tvilende til (men håpende...)
Tesla X90D 2017
Nissan Leaf 2012
  • Full Member
    • Vis profil
« Svar #4 på: Fredag 27. April 2012, klokken 23:58 »
Var ikke en av årsakene til at kladden er så nært stikk-kontakten at den slår på strømmen bare når den andre enden er plugget inn i bilen og kommunikasjon mellom kladden og bilen er etablert. Dermed kunne man sannsynligvis ta en saks og kutte kablen uten at det ville skje noe annet enn at ladingen stopper. Gjør du dette med den svenske kabelen må du håpe på en kvikk jordfeilbryter...
Blå Leaf, Tromsø
Ladefabrikken
  • Hero Member
    • Vis profil
    • Ladefabrikken
« Svar #5 på: Lørdag 28. April 2012, klokken 00:13 »
I den store ladekladden er det rele og elektronik som lager et pilot signal til ladern om hvor mange amper laderen skal trekke. Rele er der for at det ikke skal være noe strøm i ladekontakten når man tar den ut fra bilen.
Jeg regner med at her har man bare kuttet ut alle relene og har bare et lite kretskort som lager dette pilotsignalet til laderen.
Da blir det som en helt vanlig kontakt som vi har i de gamle elbilene med strøm i kontakten hele tiden.
Den store kladden er nok lagd fordi man skal selge Leafen i USA og da må man sikre seg i hue og ræva for at dume amrikanere ikke skal få støt og saksøke dem etterpå.
1 Stk sort Leaf
Salg av ladekabler
gbzdoc
  • Gold Member
    • Vis profil
« Svar #6 på: Lørdag 28. April 2012, klokken 00:22 »
Ikke noe problem i dag å få plass til nødvendig elektronikk og relé både i ladepistolen og støpselet.
Bare å se hvor liten en 120A fartsregulator til RC biler er så skjønner man at det har skjedd noe siden Tamiya var det hoteste man kunne ha... ;-)
Kladden fra Panasonic må være fylt med bly, bare for å tilfredstille amerikanerne. Akaurat som at de på død og liv skulle ha antenne på mobilene sine i mange år etter at det forsvant i Europa.
Ladefabrikken
  • Hero Member
    • Vis profil
    • Ladefabrikken
« Svar #7 på: Lørdag 28. April 2012, klokken 08:11 »
Prisen blir 4700skr plus moms.
Han trodde at han skulle være ferdig med testing og CE merking om en måneds tid.
1 Stk sort Leaf
Salg av ladekabler
Kryten
  • Sr. Member
    • Vis profil
« Svar #8 på: Onsdag 20. Juni 2012, klokken 11:04 »
Noen anelse om hvorda det ligger ann her? Får ikke tilgang til nettsiden han poster. DNS feil...
Denne hadde vært heftig å hatt ja.
Rød LEAF hentet 30.6.2012  - EL 17307
ELM327 med bryter for CAR-CAN til EV-CAN
Kryten
  • Sr. Member
    • Vis profil
« Svar #9 på: Tirsdag 26. Juni 2012, klokken 10:09 »
Ser at denne svenske karen skal ha sin EVSE inne til EMC og LDV test i morgen. han mener også at den tilfredsstiler kravene for CE merking. Gode nyheter. Spennende å følge med. Lurer fælt på hvilken pris han legger seg på.
Tror jeg må besøke min svenske slektninger når denne kommer for salg ;)
Ladefabrikken
  • Hero Member
    • Vis profil
    • Ladefabrikken
« Svar #10 på: Mandag 02. Juli 2012, klokken 08:34 »
Nå kan man gå inn på denne siden http://www.charge-amps.com og resrvere en kabel
1 Stk sort Leaf
Salg av ladekabler
Kryten
  • Sr. Member
    • Vis profil
« Svar #11 på: Mandag 02. Juli 2012, klokken 08:38 »
Reservert. Gleder meg til det kommer mer info om pris og leveringstid
hkaspenberg
  • Gold Member
    • Vis profil
    • Aspenberg Consulting AS
« Svar #12 på: Mandag 02. Juli 2012, klokken 08:42 »
Ditto.
Skrevet fra det solfylte Spania.
;-D Hans
asbkar
  • Full Member
  • i-Miev 2011 (solgt), TM3 2019
    • Vis profil
« Svar #13 på: Mandag 02. Juli 2012, klokken 12:58 »
Så kjekk ut den der, så ditto!  :)
Fra Ski. i-Miev siden september 2011. TM3 siden mars 2019.
Finnøy (Arne Johan Larsen)
  • Gold Member
  • Elbilentusiast
    • Vis profil
« Svar #14 på: Mandag 02. Juli 2012, klokken 21:27 »
Virkelig spennende :-)
