Laddning med type 2 til schuko + zaptec portable
Startet av jotuc, tirsdag 23. juni 2020, klokken 23:36
jotuc
Hej!
Som rubriken lyder så undrar jag om det är möjligt att ladda på offentliga ladestationer med en type 2 til schuko adapter + zaptec portable.
Ladestationen är på 3.6 kw/16A men zaptec portable vill jobba med 2.3 kw/10A. Blir det ett problem, eller klarar zaptec portable den skillnaden?
minibiti
Should work fine.
The Zaptec will draw only 10A from the charger but the charger does not care :)
Oslo
2020 Zoe Intens R135 (Jan 2020 - present)
jotuc
Ok, sounds great :+1:. I cant load at home, and i dont want to load with 22kw all the time. So i will try this solution.
minibiti
Just remember that you will get around 1.7 kW to the battery pack.
The efficiency when charging at 10A is quite low, around 70/75%.
So don't count on getting 2.3kWh extra in the battery pack every hour ;)
Oslo
