My Renault app
Startet av minibiti, mandag 11. november 2019, klokken 08:29
hsa77
Sitat fra: kjartanb på torsdag 09. januar 2020, klokken 08:07
Idiotspørsmål, hvor finne man aktiveringskoden?
Du skal ha fått en epost da appen ble lansert. Min epost gra Renault  ble klassifisert som søppelpost av gmail.
2015 Renault ZOE Intense (R240) - solgt
2017 Renault ZOE Intense ZE40
2014 Tesla S85 (classic RWD med AP1)
Øystein Fjelldal
#46
Er det noen med nye Zoe 50 som har full funksjonalitet på appen ? Som f.eks bilens posisjon ?
minibiti
Yes sir, it is working for me :)
But it looks like you are missing several things, like the SoC and the remaining range you can drive with it.
I am not sure at all how you can check how many of your connected services are missing...
2020 Zoe Intens R135 (Jan 2020 - present)
Øystein Fjelldal
#48
Missing a lot, but I don't know how to get it. Have reset and created new accounts and reconnected, but no luck. Guess I have to contact dealer.
minibiti
Yes contact your dealer. He will have to contact Renault so they can check what is wrong with your car or your account.
If you really want to test more on your own, you can install the French APK of the My Renault app.
You can then log on with the same My Renault account but you see all your connected services there and what is enabled and what is not.
I see 4 different connected services pack in mine:
OTA Firmware update
Pack Remote EV
Connectivity Pack
Remote Car Dashboard
I can send you the APK if you are using Android :)
Marius Jacobsen Eggerud
Sitat fra: Øystein Fjelldal på tirsdag 14. januar 2020, klokken 10:16
Akkurat samme problem som meg. Finner ingen løsning.
minibiti
Now it is not working for me either :(
They are probably fixing something on the servers for all of us... ;)
Sitat fra: Marius Jacobsen Eggerud på tirsdag 14. januar 2020, klokken 13:30
Har prøvd å logge ut og inn igjen. Da mistet jeg flere funksjoner, så nå har appen ingen funksjon. Veldig imponert.
minibiti
It is coming and going at the moment... They must be doing some work on the servers...
minibiti
Better for me today...
What about you guys?
BTW, do you have the following menu in the Easy Link?
From the "Car info" menu, then the "Vehicle" tab, access the "Energy info" menu to view the vehicle's energy consumption.
Sitat fra: minibiti på onsdag 15. januar 2020, klokken 13:26
Today is even worse than yesterday. Lost the only two features I had, so now the app is completely useless and featureless.
Kaspers1
Virker ikke hos meg heller. Har satt forhandler «in action»...👍😊
Hva kunne de bidra med? Jeg fikk beskjed om at det ikke vare noe annet å gjøre enn å vente.
#58
Android oppdatering ute nå. Fikk en ny fane kalt: Agenda for bilen min. Denne sier noe om serviceintervall og hva som utføres.
NB! Denne oppdateringen roter til Lade- og klimastyringen, så er dette en funksjon du bruker ville jeg ventet med å oppdatere. (Min erfaring.)
Svein_H
Installerte appen på jobbmobilen for å teste den, logget inn og registrerte VIN-nummeret på bilen min, og fikk da beskjed om at appen ikke var kompatibel med bilen... Kan det være fordi jeg deaktiverte datadeling fra bilen her om dagen (så ikke poenget med datadeling etter at de la ned My ZE Online), eller er det rett og slett ikke meningen at jeg skal få 'gleden' av å bruke denne nye og flotte appen de har gjort seg slik flid med..?
2021 Zoe Zen+ R110 (2024-)
2018 Zoe Intens R90 (2018-2024)
2013 Focus Titanium 1.6 EcoBoost stv (2012-)
2004 Dethleffs Advantage Globetrotter 2.8 JTD (2021-)
