Overwriting TPMS IDs via CanZE
Startet av minibiti, mandag 28. oktober 2019, klokken 11:44
minibiti
I have the latest version of CanZE (1.45) on Android but when I try to overwrite the tires pressure sensors registered with new IDs so they match the winter tires ones, I get an error.
Do other people have the same problem?
Oslo
2020 Zoe Intens R135 (Jan 2020 - present)
HCO
Ja, samme problem. Får lest ut gamle adresser fra bil-minnet, men ikke skrevet nye.
2019 Tesla Model 3 LR AWD
2022 Zero SR/F
minibiti
OK then I will dare reporting a bug on their Github repo :)
Oslo
minibiti
According to the CanZe people, some dongles are not good enough, e.g ELM327:
https://canze.fisch.lu/elm327/
So this won't work for those of us who use this dongle :(
Oslo
minibiti
It might not be the dongle after all...
Follow the issue directly on Github, here:
https://github.com/fesch/CanZE/issues/577
Oslo
HCO
CanZe 1.47 er kommet, jeg håper den fikser skriveproblemet. Skal teste i kveld.
2022 Zero SR/F
minibiti
Dont! It made it worse.
Follow the link to issue 577 above
Oslo
HCO
2022 Zero SR/F
minibiti
The latest version of CanZE ( 1.48) allows to write the TPMS IDs, but you have to write them one at a time.
More info at the end of the thread for the bug report: https://github.com/fesch/CanZE/issues/577
Basically, you can skip valves by entering value 0
Oslo
HCO
Takk for tips. Fungerte perfekt nå, ved å skrive en adresse av gangen, og la det stå 0 i de andre.
2022 Zero SR/F
Tormy
OK, I'll bite :-) Hvordan får man tak i ID på TPMS og får matchet den med riktig posisjon? Er det slik at det dukker opp ID'er i CanZE som man så kan brkrefte, eller må man kjenne til ID via ekstern leser el.l.?
minibiti
Usually what you do is this:
1. Read IDs from first set of tires (say summer tires)
2. Take a screenshot of the first set
3. Get a new set of tires (winter tires)
4. The people doing that screw up and overwrite the first set of IDs instead of cloning them to the new sensors
5. Read the new IDs
6. Take a screenshot of the 2nd set
7. Spring comes, put back summer tires on
8. Read TPMS IDs and find out that the on board computer still has the winter tire IDs
9. Find screenshot from step 2
10. Overwrite values on the on board computer with the values from step 2
11. On board computer can now relate to your summer tires and you can read the pressure
12. Same dance each time you change tires twice a year :)
Oslo
HCO
#12
Jeg forsøkte å få lest av adressen på "løse hjul, men de hadde ikke utstyr til det på dekkverkstedet jeg bruker.
Dersom du har feilmelding nå, etter omlegg til vinterhjul, bør du derfor bruke CanZE og lese av adressene som ligger i bilen. Dette vil da være adressene til sommerhjulene dine. Kjør deretter til et Renault-verksted og be de matche bilen mot vinterhjulene som står på. Vel hjemme igjen kan du da lese av vinter-adressene. Til våren slipper du da turen til Renault, ved at du kan bruke CanZE for å legge tilbake sommer-adressene.
2022 Zero SR/F
minibiti
The Renault Garage should manage to clone the winter and summer sensors if you go there with both sets of tires.
I do hope they are used to doing this by now...
Oslo
HCO
Minibiti, man kan ikke skrive til vanlige TPMS-sensorer, de har fast adresse. Så om man allerede har 8 hjul med faste adresser, er CanZE beste løsning.
Klone-sensorer koster typisk ca 2000 kroner, pluss jobben med å ta dekkene av og på felgen. Om man ønsker å bytte til slike, bør man gjøre det når man aliikevel trenger nye dekk.
Vi har 2 Zoe'r, og har klone-sensorer på den ene. Tenkte å bytte på den andre, men nå er det så enkelt med CanZE at vi velger å spare de pengene.
2022 Zero SR/F
