Nyhetsbrev
E-post *
Skrevet av Emne: Think Tech centre  (Lest 1132 ganger)
Teasie
Think Tech centre
« på: Fredag 27. ſeptember 2019, klokken 12:58 »
Hi folks,
anybody here, who can explain me to connect the "Think tech centre" software with Think City canbus?
Thanks
Matthias
pexic
Sv: Think Tech centre
« Svar #1 på: Mandag 30. ſeptember 2019, klokken 16:00 »
Hi, you need a special adapter, it is very hard to find such adapter.
For the "tech centre" manual you can send me a private message with your email.
Viorel
worry
« Svar #2 på: Tirsdag 08. Oktober 2019, klokken 08:21 »
There are lot's of us who would like to have this adapter.
Anyone know why it's so difficult to find such?
Is it possible to reengineer this adapter and make new ones?
I paid 300 euros to get the pcan adapter, and I would pay the same amount to get this one.
Thanks.
Think lithium
pexic
« Svar #3 på: Onsdag 09. Oktober 2019, klokken 07:39 »
Hi Worry & all
I was in same situation till I find out how to use CHAS, his interface is ugly indeed but it does almost  the same as tech center (except programming new keys).
Try it and maybe it helps, the only adapter needed is Serial to USB ;)
worry
« Svar #4 på: Onsdag 09. Oktober 2019, klokken 10:03 »
I tried some months ago, but did not see any contact with the car.
Do you use the pcan adapter? Is there a detailed instruction somewhere?
Thanks.
« Siste redigering: Onsdag 09. Oktober 2019, klokken 13:39 av worry »
Think lithium
pexic
« Svar #5 på: Onsdag 09. Oktober 2019, klokken 18:00 »
No PCAN adapter, just serial to USB if your computer does not have serial com port.
The CHAS  manual (instructions) can be found inside think.zip archive ;)
You only need a cable adapter , there is info in one of my posts if i remember well..
And other info regarding this cable, tge plug location (under fuse panel) can be found on this forum also, bow i'm mobile and i cannot search , sorry
worry
« Svar #6 på: Torsdag 10. Oktober 2019, klokken 14:52 »
Thanks,
Found it. I remember now that I've read it before.  :+1:
Think lithium
Teasie
« Svar #7 på: Mandag 02. Desember 2019, klokken 20:43 »
Hi, can anybody tell me where i can get CHAS Software?
pexic
« Svar #8 på: Tirsdag 03. Desember 2019, klokken 11:11 »
Teasie - check the private messages  ;)
Teasie
« Svar #9 på: Mandag 13. Januar 2020, klokken 20:48 »
Hi Folks, thanks a lot for support. Now I am connected with my Th!nk, it's a Zebra Gen1.
I read out with CHAS, Zebra Monitor and PCANview. All I can see, everythink is OK no Error Code found.
But Zebra is heating, saying ready, but charging didn't start  :'(
Anyone a Tipp - I mean the last thing todo is to throw away a very nice car with a Zebra in best condition (no faults).
best regards
Teasie
BauDemo
    • www.uppladdning.nu
« Svar #10 på: Tirsdag 14. Januar 2020, klokken 12:39 »
Maybe look at the data that CHAS shows you and try to analyse it?
For example look at the fault code bytes.
Teasie
« Svar #11 på: Tirsdag 14. Januar 2020, klokken 13:31 »
Hi, ther are no fault codes all bytes 0.
BauDemo
« Svar #12 på: Fredag 17. Januar 2020, klokken 15:13 »
It will be hard to guess what it could be.
Please publish here a screenshot from CHAS when the car has a charged 12V battery and the start key is in position II.
Teasie
« Svar #13 på: Lørdag 18. Januar 2020, klokken 12:29 »
You mean something like this?
BauDemo
« Svar #14 på: Mandag 20. Januar 2020, klokken 14:08 »
Yes, like this, but I usually get much more parameters... Did you open correct var file?
Have you translated the meaning of all the parameters you see?
The BMI reports 0% SOC...
The voltage of the battery is very low...
Can you try to select correct .var file, and then try to charge (plug the blue plug) and take another screenshot.
