Skrevet av Emne: RS485 communication standard Charger to BMS  (Lest 561 ganger)
BauDemo
    • www.uppladdning.nu
« på: Onsdag 22. Mai 2019, klokken 13:54 »
Is there any place where I can download/access the standard used between the charger and the BMS in the Think?
I am troubleshooting a broken charger and it would make it much easier if I can isolate eventual problems.
Sv: RS485 communication standard Charger to BMS
« Svar #1 på: Fredag 24. Mai 2019, klokken 06:56 »
I can not help with such info, but a way around is to use a Renault Clio comunication card in the Charger for fault finding purposes. This card will allow charger to start charging for a second ore so even without communication.
Har hatt Cree SAM og City el
Har for tiden Tesla S85, Smart ED, BMW C- evolution, Citroen C1 EVie, Berlingo, div. Think og PSA Classic og City 2010 model, Chin 3 hjuler Pickup, Buddy M9 samt Vectric scooter. Kjøpt Fiat X 1/9 for elektrifisering og venter på Microlino, Aptera #2246 og Sølv Monotrazer MTE-150 #7042
BauDemo
« Svar #2 på: Fredag 24. Mai 2019, klokken 07:11 »
Thank you - don't have such card yet.
But I have a RS485 adapter that I may try to connect and see...
BauDemo
« Svar #3 på: Torsdag 30. Mai 2019, klokken 19:00 »
I managed to log the messages from the BMS and published the preliminary results here for future reference:
https://www.evmonitor.info/2019/05/i-had-chance-to-log-messages-that-bms.html
I could not find a good way to easy listen to the traffic, so there will be some time before I log the messages from the charger.
Nikolay
