More than max error ?
Startet av Frederic, lørdag 18. mai 2019, klokken 20:27
Frederic
Hello,
Upon reconnexion of the repaired battery, we have this error message ......
Mstr_Malf_Codes1
00 00 08 00
"More than max error "
Do you know what it is ?
Regards
pexic
Salut Frederic
A print-screen of the whole data will help more, I think. I assume is an error reported by Comtool..
bye
Frederic
Merci Pexit
here is a pdf of the comtool file
see page 10,13,15,16 and 17
where have you found the "siadis" connector ?Du kan ikke vise dette vedlegget.
Regards
pexic
Please see the picture from this post :
https://elbilforum.no/index.php?topic=45999.msg798897#msg798897
This connector is under the FUSE panel (torpedo) passager side. (For zebra cars it may look different - maybe rounded)
No idea about the data from .pdf since I have Enerdel Li-ion battery and your data looks very different, please wait and maybe some other forum user(s) will help you with that.
Regards
Viorel V.
