Enerdel battery fault - repairing...replacing...
Startet av pexic, tirsdag 23. april 2019, klokken 15:56
worry
Hi. I'm not the real specialist here, but I can try:
When I read my own car I do it with the battery connected to the car and from the diagnose plug on the dasboard. "Ignition" on.
Think lithium
pexic
@jur
check in commtool (upper right) if "Rcv. Range is 61E - 61F.  if not- please input these values and try again (CAN Bus must be checked also)
jur
Thanks a lot Pexic,
after setting the range the tool worked fine. Now I'm drowning in data  ;D
Regards,
Jens
pexic
#63
Huston we have another problem(s) :)
My dear Think refused to start after 2 weeks pause.
Charging is ok, all is ok till key=on inclusive. At key=start (crank) -> nothing changes, no green little car... :(
Using CHAS I found two main differences -> see picture.
Errcode=41  and
"Iac_fault = true"
Also I have recorded the start sequence while I've tried Key=start three times  (see error41.jpg file attached - renamed from .trc)   Du kan ikke vise dette vedlegget.
Does anyone knows what Iac_fault is ? how about error41= driver gate error ?
Thank you in advance.
Viorel
pexic
Hi
I've noticed another error- see picture above - FlSt5 (flag status 5) bit 2 = 1
This means:  PCU Gen2 immobiliser error - no communication to antenna
I'll investigate this first and I'll let you know.
Regards
Viorel V.
pexic
Ok, some WD40 on "immobilizer" antena module plug and victory! little green car is ON :)
I still have error 41 but I can forgive this error now :)
Regards
Viorel
worry
Think lithium
pexic
Hello friends !
Since winter is comming, again, I was force to finish the webasto airtop installation.
Here are the pictures: Du kan ikke vise dette vedlegget.  Du kan ikke vise dette vedlegget.  Du kan ikke vise dette vedlegget.  Du kan ikke vise dette vedlegget.  Du kan ikke vise dette vedlegget.  Du kan ikke vise dette vedlegget.  Du kan ikke vise dette vedlegget.
EXCEL
Er det noen som vet hvor jeg kan få tak i: elektriske tegninger til RLEC kortet, som det sitter to av på toppen av hver batteri boks?
Full elektrisk fra 18.06.16
e-Golf (2014) mars 2019
Model S 75D desember 2017 oppgradert til MCU2/HW3, CCS og takfeste.
Think Lithium 4-seter (2011) 18.06.16
Model S 70D 20.11.15 (Solgt)
e-UP (Solgt)
Think Zebra (solgt)
worry
Det tror jeg ikke finnes tilgjengelig for oss entusiaster.
Visstnok har en (eller flere) laget tegning selv, med tanke på produksjon. Men det var komplisert, eller ikke lønnsomt, og stoppet der.
Think lithium
pexic
Hey, Worry is right :) it is complicate to repair those RLEC modules, look for some to buy them, you can still find some.
