Skrevet av Emne: Replacing and relocating the 12V battery - think ..U0060..  (Lest 425 ganger)
pexic
  • Jr. Member
    • Vis profil
« på: mandag 22. april 2019, klokken 18:55 »
Hello friends
Utill my friend will come and help me to remove the Enerdel defective battery I was starting to replace and relocate the 12V battery since I will need to connect/dissconect it quite often during the whole time while my Think will be restored/repaired in my garage.
I have AC so it was quite difficult to find a place for the new, smaller and only 5Kg, Lithium tithanate battery.
I found this temporarily solution :
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
If this location will remain the final one then I have to think for some water protection.
Thanks for reading and for future feedback.
BauDemo
  • Hero Member
    • Vis profil
    • www.uppladdning.nu
Sv: Replacing and relocating the 12V battery - think ..U0060..
« Svar #1 på: tirsdag 23. april 2019, klokken 09:44 »
This is where my Think has a cabin air inlet... and deep behind your battery I think I can see the cabin filter still there...
Also what is keeping the battery from lifting up when you drive thru a bump on the road?
pexic
  • Jr. Member
    • Vis profil
« Svar #2 på: tirsdag 23. april 2019, klokken 15:30 »
Hello BauDemo and thank you for your feedback.
Same in my case, I don't see too much trouble to change the air filter, I have to seal the usual air inlet from the hood but I don't think this would be a problem also.
I will be fixed, the work is in progress :) I just have to stop here regarding 12V battery since my first goal has been reached :  Now I can easily connect/disconnect/measure the 12V battery.
I need this feature since I'm starting to repair the Enerdel battery.
Have a nice day!
Wolfgang Mayrhofer
  • Newbie
    • Vis profil
« Svar #3 på: torsdag 29. august 2019, klokken 10:59 »
Hi,
as I am thinking of a similar solution:
why did you use 5 cells? shouldn´t 4 cells be enough?
Wolfgang
pexic
  • Jr. Member
    • Vis profil
« Svar #4 på: lørdag 31. august 2019, klokken 21:48 »
Hi Wolfgang
It depends what kind of cells do you use.
If you choose LiFePo4 type (3.2v per cell) then 4 cella will be ok.
I use Lithium Tithanate  Oxyd cells (2,4v per cell) so I needed 5 cells .
