Looking for Marechal fast charger cable connector
Startet av pH03N1xM, onsdag 06. mars 2019, klokken 08:46
pH03N1xM
Welcome!
Im looking for Marechal fast charger cable connector for my good old Saxo. Yes, i know it was not available for public, but maybe someone have one spare...
Thanks!
Laszlo
Citroen Saxo Electrique 1996 with NiCd
Peugeot Partner Electric 1998 / Citroen Berlingo Electrique 2000 (both under rebuild)
timescape
pH03N1xM
Have you some detailed pictures about the installed pins?
Thanks!
timescape
No,
I took over the project from somebody else..
Took me some time to correct and assemble.
You need:
- 2 blocks of brass. Shaped as a small "inverse L"
- 2 springs
- Parts of a bike chain.
- a dremel
- a lot of patience :)
The Brass block shall be made so it can move freely up/down.
You will not be able to run a lot of amps though this solution. I run aprox 20A..
(I applied som silver coat to the contact point as well).
I will provide some more pictures when I got the time. :)
br.
pH03N1xM
I plan to run 30-32A max, so i guess this mod will be suitable. I have the needed parts as i see. Hower, maybe i wait to get some pictures ;) Thx!
Elmo
#5
Sitat fra: pH03N1xM på onsdag 06. mars 2019, klokken 08:46
Call +4795991227 and say hello from me.
I think he may still have several brand new ones
eUp 2015 - solgt.
