Wallbox as charging point and extension cable.. Does it work?
Startet av Cloggy, torsdag 31. januar 2019, klokken 17:35
Cloggy
Hi..
Writing in English, but feel free to answer in Norwegian..
I have a Siemens wall charger (2015 installed) with fixed charging cable for th E-Golf.
Now I would like to extend the length so that other cars can be charged outside the garage as well.
One option is to buy a new fixed 8m cable or I could buy a 5m extension cable.
The extension cable that came with the E-Golf does not work. Guess there is some safety build in to prevent disconnect. But how does that work with the extension-cable I could order online?
Regards,
Onno Bruin
All mode 3 cables are made to not work as extention cables.
We can supply you a 10m 3,6 kW replacement cable if needed.
